Storm damage
paulus
Carlisle
Got up Friday morning to suspect that a small piece of masonry had been detached from the garage roof and fallen onto my MG4 Trophy - breaking the plastic cover on the nearside rear lights. I was less bothered about the small dent which may have been the result of out bin flying into it, since the paint is not broken and I looked into just replacing the broken plastic cover. To my horror I discovered today that I cannot replace the cover, since only the full light assembly is available at a cost of £312. Since the MG4 is a newish model I guess I have no alternative - unless someone knows differently.
Has anyone any experience to advise how difficult fitting a replacement might be?
Thanks.
Reviews on the AliExpress ones are not brilliant. May opt for used one from ebay. Just need to discover how to remove/replace.
Fitting a replacement is easy. Two bolts and a wiring plug. See this thread about replacing the reversing lights with LEDs
Check with your dealer's parts department on how much a replacement will cost to give you some idea if used ones are a good deal.
    Votes: 1,069 77.7%
    Votes: 208 15.1%
    Votes: 100 7.3%
