System powers up after shutdown
Badger192
Blackpool
Mornin' Folks,
I bought a 2023 MG4 SE standard a couple of weeks ago and in the main, I'm reasonably happy with it (1st EV I've had).
When i shutdown the car from the screen menu it powers down OK (radio stays on) but when i open the driver's door and start to get out the system powers up again (headlights back on etc). It also powers up when opening the driver's door as I'm getting in (from locked).
I'm definitely not making contact with the brake pedal at any stage of exiting or entering. I was under the impression that it only powered up once the brake pedal is depressed?
Possible software fault? (installed software version is R13)
It's booked in to have the software updated on Wednesday and I've mentioned the powering up thing to them...
I'm still in the 30 day 'rejection' period for a faulty car - would just like to know if it is actually a fault or normal?
Cheers
Just a side effect of your rear end being the on switch. I have had times when I just reached into the car for something and too much pressure on the drivers seat cushion fires things up.
You have to pretend you are in Mission Impossible and leave the car without putting any pressure on the drivers seat
It's just because the driver's seat switch is too sensitive, it's impossible to get out of the car by simply lifting your bum off the seat, there's inevitably a bit of shuffling as you get out, so you inadvertently put a bit of weight back on the seat and power the car up again. I now know I have to get out of the car, and reach back in to do the final shutdown confirmation press.
    Votes: 1,036 77.7%
    Votes: 202 15.1%
    Votes: 96 7.2%
