siteguru
Distinguished Member
- Sep 3, 2022
- Solutions
- 3
- Location
- Strathaven (SE SR MY22)
- MG4
Got my car back from 1st service today and it has 1100R33 Infotainment software. This thread is to record some details and observations regarding it.
Edit: details of how the USB input now works for Music can be found in the post linked below:
www.mgevs.com
- Exact version numbers are MPU SWI69-29958-1100R33, MCU 69.3.8.0:
- It has the new AC page, and the top bar is always visible:
- And the AC popup is the new style:
- As the top bar is always visible then there is easy access to the pull-down menu. This includes the option to turn off LKA (called LDP on the menu) - it works as per the Car screen menu and gives a Confirm prompt:
- The left and right Star buttons now have the same three selection options:
- I have the right Star set to AC and left Star set to Regen ... pressing the left Star cycles through the regen modes ... 3 -> A -> 1 -> 2 -> back to 3
- ACC functionality is now inverted ... get to a speed, press the middle-left button and it engages at that speed. Press up/down on the left joystick and it now increases/decreases by 1 mph; press and hold up/down to change to the nearest 5 mph and increment in 5 mph steps.
- When I got back home, locked then unlocked the car and sat in the driver seat I was presented with a setup screen - this was just to set the language, time zone and 12/24 hour clock.
- I was also presented with the Intelligent Battery Heating prompt - I ticked the box and pressed Cancel.
- I had to reselect my phone from the Bluetooth screen to connect, although it was remembered as a previously-paired device. Once done it synched and all seems OK.
- Android Auto worked straight away when I collected the car. After doing the above Bluetooth procedure I checked AA again and it still works OK.
- I had to redo all my radio favourites. The update wiped them out.
- Edit: So far the radio has been off when I've unlocked and sat in the driver seat, even if it was on when leaving - need to monitor further. Still remaining off when unlocking the car and sitting in the seat.
- Edit: I selected Sport mode on my drive home and then checked the Infotainment screen - it still showed Sport rather than switching to Snow like it did previously.
- Edit: I don't have a USB pen drive with music on it so I am unlikely to test Folders - I never use that method for music; it's either Bluetooth or Android Auto.
- Edit: I'm heading down to the homeland on Saturday so I'll check the SoC bar colour then.
- Update: remote HVAC now works when plugged in but not charging. ?
New software installation
How do you go about getting a software upgrade? Do you have to take the car to the dealership or can it be done at home? I am interested in installing the new 33 software.
