The MG4 SE 1100R33 Infotainment Thread
Well, they haven't done it again, so maybe I just accidentally flicked the wiper stalk twice.
I think the car is pre-heating when plugged in but not charging, but it didn't really get warm. I think it was trying to power the heater from the granny lead and couldn't get enough juice.
Yeah that’s the problem: when plugged in the granny there’s just not enough juice.
Is the only reason I would ever consider installing a 7kW charger but I’m happy to simply use the battery.
Hi all, Just got my SE updated to R33. All OK but I am experiencing a speed limiting issue. Power % starts to drop as speed increases. Max speed is 114KM/h (70Mph). The accelleration rate has decreased drastically to the point that I am afraid to overtake. I tried full charge with balancing, disconnected negative 12v. All for nothing. Any hints appreciated.
UPDATE: Dealer refreshed software update and issue is now resolved. Now a happy R33 (and related modules) user.
Has anyone noted that if the A/C is off, every time you adjust the fan speed or temperature, A/c switches on.
Also, the custom drive mode does not 'remember' the pedal force setting.
Happens in my Trophy, really annoying. Though I think in the latest update I had (1300R46) the fan speed doesn't do it any more, but I'd have to double check.
I always have AC enabled so it's not something I'd spot - so I've no intention of checking the behaviour. :)
As to CUSTOM drive mode - I can't remember what I'd set. (I think it was Normal drive mode and everything else Sport. I'll try to remember to check next time I'm in the car).
I have noticed that the left star button had recently lost its setting. I have it set for drive mode and when driving it on Sunday I noticed that the button did nothing. It was easily reset back to drive mode though. Something I'll keep an eye on.
I had the same issue with the right star, on R13. I was showing a friend how to drive the car, and she couldn't get the HVAC to work from the steering wheel button and neither could I. When we got back I went into the menu and it was correctly selected. But I deselected it and re-selected it again, and it as fine. That was four months ago and it hasn't done it again.
Just been out to the car and checked it again - it's still set correctly. Maybe it's a time-based issue, as I'd had that setting for months but only recently found the issue. 🤷‍♂️
PS - I forgot to check the CUSTOM setting.
Edit: went back out and checked the Custom settings. Pedal Force was at Normal, but I can't be certain I didn't set it that way. I've set it to Sport and will monitor. (Drive was Normal and Steering was Heavy, as I expected).
    Votes: 544 79.3%
    Votes: 91 13.3%
    Votes: 51 7.4%
