Alb
Moderator
- May 11, 2021
- Solutions
- 6
The car was on charge last night so I powered up and did a quick dashboard check this morning to make sure it had completed successfully.
Whilst doing this, I ran through the dash options and my attention was drawn to the TPMS Monitor.
You can see from the ambient temperature display (17 Deg C) that it was clearly not displaying current data. Although there must be a refresh cycle for this information, I'd have otherwise taken it for granted that a full power down/power up cycle would force the system to read fresh data but this doesn't seem to be the case.
Haven't taken the car out yet but I suspect that it will refresh when the car is moving so this is probably a design "feature" rather than fault. Either way, if you jump into your car first thing in the morning and check tyre pressures via the monitor, don't assume they are correct.
