- Sep 3, 2022
- Solutions
- 3
- Location
- Strathaven (SE SR MY22)
- MG4
Jackary?
I run a 2kW heater indoors with no problemsYeah it's an off grid camping power bank I take outside camping. Gives me 12V, 5V and AC mains. I use it for hair straighteners and radios and phone charging, but it won't run a heater, but the car will.
Could u share the link. im looking for a 32 amps V2L plug.I bought one from Ali Express for $AUD36.00 with claimed output of 32 amps. There were reviews from MG4 owners that it worked fine. Mine does too but I doubt I could get 32 amps discharge. I used it with my Karcher pressure washer for a couple of hours with no problems. I think that it was drawing about 11-12 amps.
We have a planned power outage next Tuesday for 6 hours so I will use my heavy duty 20 Amp extension lead for various appliances but not all together.
Me too, also air compressor, kettle,2kW heater... not all at once of course. Seems OK to 3kW. ? ?I've used mine with an electric chainsaw (2200w). Works fine. Also used to power the home office when they changed the consumer unit, again no problem. So I'm quite impressed with the potential should I ever get a long power cut.
I got mine "free" with my trophy model, UK spec 6mtr 2.5 mm cable water proof double elcb skt. ? ?
Yes exactly the same, plus I also got free floor mats. ? ?Is that the one that's on the MG website ? ta
My adapter arrived today. My 2023 MG4 Essence doesn't recognise it when plugged in.The adapters Ive seen on eBay warn “may not work with 2023 models”. Anyone tried one of these or know any guaranteed to work with 2023 mg4
It's advertised as being available on the mgmotor.com.au website.My adapter arrived today. My 2023 MG4 Essence doesn't recognise it
I don't have a multimeter.It's advertised as being available on the mgmotor.com.au website.
Maybe yours needs a different resistor? Can you measure from proximity pilot to protective earth with a multimeter?
Hi. I also purchased a dodgy V2L adapter on eBay which didn't work on our MG4 Essence 77. The biggest surprise was getting a full refund with free return postage.My adapter arrived today. My 2023 MG4 Essence doesn't recognise it when plugged in.
I bought this for £14 from Ebay, EV Cable Adapter 2022 MG ZS MG4 MG5 Discharge V2L Vehicle to Load UK Power Cut | eBay
Works ok with the updated 2023 MY MG4
Made a guide for anyone new V2L like me
You were lucky, I only got a partial refund of $9.60 (I had paid $32) but got to keep the adapter, which may or may not work on a different model of MG4. I will carefully consider my options before spending any more money on a non-essential item.Hi. I also purchased a dodgy V2L adapter on eBay which didn't work on our MG4 Essence 77. The biggest surprise was getting a full refund with free return postage.
We bought another type from a seller in Adelaide, but they refunded the payment 2 days later citing a problem with their stocked item.
Finally I purchased one from AliExpress and as stated, it arrived today after a month long delivery. It was a bit more expensive at AUD $83.19, but it actually works! The shape of the MG4 socket cavity means the adapter's display is slightly obscured, but still readable. There is a little switch just above the outlet plug labelled C-M-K. Select M for the MG.
Daggly
Well it's interesting about the partial refund. We may have had the same seller. I was offered the partial refund, but that was after I had previously clicked on the return/refund button and eBay allowed me to print off a return label. My surprise was that the address label said "no postage required".You were lucky, I only got a partial refund of $9.60 (I had paid $32) but got to keep the adapter, which may or may not work on a different model of MG4. I will carefully consider my options before spending any more money on a non-essential item.
Just found somewhere else that your battery needs to be over 80% - seems odd.I bought one of the eBay adaptors. Plugged it in to get a blue light on the adaptor. The charging screen on the MG4 seemed to recognise it, but when I hit 'Start Discharge', I got a message "Discharge failed - discharge cut off power is higher than . . . " etc.
