Voice commands
Is there a list of voice commands somewhere?
I've been looking for it everywhere for a while and only found the "Hector" ones that do not work... some of them will tell you "function not implemented"...
Thanks. Doesn't seem to stay on long enough.
You can still change the temp and speed without it being on the screen
Yep. Thumbstick up/down changes temp, left/right changes fan speed.
It stays active until you press the right ⭐ again, which will change the thumbstick back to controlling the sound system.
I think some people (some Trophy owners?) have an issue where the AC popup doesn't stay up for long. In my SE the AC popup does indeed stay there until I press the right Star again.
This seems to be a bug on the Trophy, and Trophy owners really need to tell MG about it. On the SE it works properly. The HVAC controls come up when you press the star button, then stay visible until you press it again. I find it really great.
However, as NewMG4me said, Trophy owners report that the function still works even if you're not seeing the screen. So you can presumably do as I do now I'm used to it. Press the star button, toggle temperature and fan up or down as required, then press the star again, all without taking my eyes from the road. Whether the HVAC controls are on the screen isn't important.
Indeed. This is how I use the function.
Good to know: I'll give it a go.
I just say hi mg, turn temp up by x degrees, or set temp to x
Setting the fan and temperature is one thing. In my Trophy, the right star menu pops up when I press the left star button - in parallel to the function set on the left. So if I set from normal to custom > climate menu. If I then want to operate the radio, I firstly have to turn the climatronic menu off manually. A really messy bug.
To operate the radio volume etc after using the right star button to change the climate controls, you have to press the star button again to cancel the climate menu, even though the climate menu has already disappeared.
    Votes: 943 77.6%
