I've been looking for it everywhere for a while and only found the "Hector" ones that do not work... some of them will tell you "function not implemented"...Is there a list of voice commands somewhere?
You can set the RH star button to bring up AC, where the toggle does temperature +/- and fan speed +/- if that helps.Mainly looking for the AC commands as it's a bit fiddly while you are driving.
Thanks. Doesn't seem to stay on long enough.
Yep. Thumbstick up/down changes temp, left/right changes fan speed.You can still change the temp and speed without it being on the screen
I think some people (some Trophy owners?) have an issue where the AC popup doesn't stay up for long. In my SE the AC popup does indeed stay there until I press the right Star again.Yep. Thumbstick up/down changes temp, left/right changes fan speed.
It stays active until you press the rightagain, which will change the thumbstick back to controlling the sound system.
Indeed. This is how I use the function.However, as NewMG4me said, Trophy owners report that the function still works even if you're not seeing the screen. So you can presumably do as I do now I'm used to it. Press the star button, toggle temperature and fan up or down as required, then press the star again, all without taking my eyes from the road. Whether the HVAC controls are on the screen isn't important.
I use the indicators to turn on the 360 cameras if needed.Is there any voice command to show the 360 camera on the screen? I know you can make it a shortcut on one of the star buttons on the steering wheel but a voice command would be better for my needs.
Setting the fan and temperature is one thing. In my Trophy, the right star menu pops up when I press the left star button - in parallel to the function set on the left. So if I set from normal to custom > climate menu. If I then want to operate the radio, I firstly have to turn the climatronic menu off manually. A really messy bug.This seems to be a bug on the Trophy, and Trophy owners really need to tell MG about it. On the SE it works properly. The HVAC controls come up when you press the star button, then stay visible until you press it again. I find it really great.
To operate the radio volume etc after using the right star button to change the climate controls, you have to press the star button again to cancel the climate menu, even though the climate menu has already disappeared.Setting the fan and temperature is one thing. In my Trophy, the right star menu pops up when I press the left star button - in parallel to the function set on the left. So if I set from normal to custom > climate menu. If I then want to operate the radio, I firstly have to turn the climatronic menu off manually. A really messy bug.
I thought I'd seen a list of voice commands somewhere on the forum, but can't for the life of me find it, can anyone help?
Can you change the volume of the voice assistant? nearly deafened me when I tried it !
