Wireless charging pad slip solution
Brettus
Solutions
Chester
MG4 XPOWER
For those with a heavy right foot or if you enjoy hooning into corners you may have noticed your phone vacating the wireless charging pad.
If you want your phone to stay there then I suggest a piece of dycem. I got a roll after discovering it in hospital. Black would be a better choice but I like blue heh.
NRS Healthcare Blue 20 x 100 cm Dycem Reel Non Slip Grip Material https://amzn.eu/d/isJth1W
Survived a planted foot launch, not tried an actual launch mode one yet but it never moved! Even though my phone has a pop socket on the back so the contact patch is reduced and CG is raised.
Thanks Brettus!
I will try this as I got fed up with launching my phone early doors and just left it plugged in, in the cup holders!!!
Yeah same, it’s no problem it being anywhere else but I was amazed how non-slip this stuff was so decided to try it. I’ve got more than I need if you’d like me to send a bit for you to try? It IS blue but it’d prove the theory.
I have these none-slip pads, the thing was that they plus the standard cover in the slot meant that it would not charge, so I removed the standard bottom of the charging tray and just used the none-slip pad, then it does charge.
My solution was to design and 3D print a phone bumper that is held in place by the mat. Even got a close match to the cars colour.
    Votes: 943 77.6%
    Votes: 180 14.8%
    Votes: 92 7.6%
