Yellow dashboard help
jackyreiki
londln
Hi my MG wouldnt start today. When I last charged it , around 10 minutes later . A warning light came on. Top left hand with a yellow road signal and saying something about ACC and the wheel. It is stuck on Neutral and won’t go in to drive or reverse: please can someone help . Only bought brand new few months ago
Those symbols at the top left are affected by the windscreen camera (behind that triangle shaped part of the windscreen glass). If that camera gets blocked (e.g. condensation or an icy windscreen) then the warnings come on to tell you that ACC and many driver assist functions are disabled (until the camera can see). These shouldn't stop the car from being able to be driven though.
Have you tried rebooting the Info screen? (Press and hold the physical Home button until the screen turns off and reboots)
If that doesn't work, open the bonnet and disconnect the negative lead from the 12V battery. (You'll need a 10mm spanner). Leave it off for 10+ minutes then reconnect it. (If you do this routine then you'll get warnings about recentring the steering wheel and resetting the window controls ... how to do so are linked in the WiKi / Tips thread at the top of the forum).
    Votes: 1,099 77.8%
    Votes: 212 15.0%
    Votes: 103 7.3%
