Rolfe
Moderator
- Apr 10, 2023
- Location
- West Linton, Scotland
- MG4
I came across this comment on a YouTube video by a commentator going by the handle of NIanais.
I'll quote the important part here. (She - I assume she, because of the feminine avatar - also goes on to criticise MG's customer service, in terms we're all familiar with.)
To begin with, we must stop confusing the two battery chemistries at the BMS software level. The BMS degrades the LFP battery by following a schedule of -0.01% every day, whether the car is used or not. While the NMC remains at 100% even after a year of use and more than 30,000 km. So there is a big BMS charge manager problem.
The second important point is intelligent heating. Here too, MG confuses the two chemistries. An NMC needs just over 10 degrees Celsius to start charging in high speed, while LFP chemistry requires 25 degrees Celsius to charge quickly. The problem is that MG has introduced a battery heating start threshold for both versions at less than 10 degrees, which slows down charging and damages the chemistry at the same time. CATL tested these batteries before delivering them to MG, which was unsure how to properly integrate them into the car. The proof is that CATL indicates that the charging power can reach 117 kW. Tesla also sources from CATL, and their charging speed is more than adequate. So, when you hit the road for a long journey, it's a disaster with this MG4S 51 kW because of the battery heating which never turns on before a charging station, since the average temperature while driving remains above 10 degrees.
This is way above my pay grade, but does anyone have any clue what she's on about?
