- Feb 7, 2024
- Age
- 70
- Mannum South Australia
- MG4 (2022-2025)
It might happen one day, but it will be an after market add on, but active balancing using induction coils is the way to balance an out of balance pack quickly.Having dealt with a neighbour’s out of balance pack before, the only solution was to open up and then bring up the low voltage cells to match the rest of the pack.
Specialist garages like Cleevely can help with EVs but IMO the pack top voltage is 3.65 volt as BMS is continuously trying to top up the low voltage cells. IMO balancing isn’t kicking off.
It basically takes the current from the high voltage cell, and feeds it into the low voltage cell. All the time there is a differential of greater than 5mV between the highest voltage and the lowest voltage cell, the balancer is active, below 5mV (0.005of 1v) the balancer shuts down.
A comparison, a lossy type resistor balancer to balance a 156Ah cell that was 10% out of balance, it would need to burn off 15.6 Ah of capacity out of the high cell by turning that 15.6Ah of electrical energy, into heat energy using a resistor.
An active induction type balancer, to correct the same 10% out of balance needs to move 7.8Ah from the high cell to the lower cells. Even if it only moved 1 Ah per hr, it would balance the pack in 7.8 hrs. Most induction balancers can shift between 5 Ah per hr if the voltage differential is high enough, but as the voltages start coming closer together, the less it can shift.
In the house battery systems I was building before my workshop was burnt down, the induction balancers would have a 48V 600Ah first charged battery pack, fully balanced, within 8 hrs with all the cells at 3.45V. They work and they work well, lossy resistor type balancers can only handle low current because the heat generated would burn them out.
If they tried to handle even 0.5 Ah per hr, it would take 31.2 h to bring that 10% out of balance high cell voltage down, but the heat generated through the circuitry and that resistor would most likely not last for 31.2 h.
The claim a resistor type balancer can keep a balance pack balanced is even questionable. Those that say once the pack is balanced, it will stay balanced, aren't using all the numbers in the equation. The difference in cell internal resistance creates a different capacity loss each time it discharges and then recharges, resistance at a cell connector generating heat rather than moving current in or out of the cell .... these are just a few of the things that will cause a battery pack to go out of balance. These cells are mass produced, they all have +/- tolerances that are acceptable to remain A grade cells.
Cell balancing will be the next critical step in the EV lithium battery evolution, the higher the capacity of the cells in the battery pack, just exaggerates the problems if the balancer is not up to the task .....
Sorry, another ranting sermon .... I should stick to the humours comments, they are always a lot shorter
T1 Terry
