OriginalBigAl
- Jan 31, 2023
- Location
- France SE,LR23
- MG4
Has anyone had to use this booster or any other in anger and did it work as expected? We all think we know the theory of how to use them on a EV but does that match the actuality. Scenario, you get back to the car and its dead, you had the foresight to buy said item, so dismantle the key ring gain access to car , lift bonnet and connect your Noco, car comes to life, what next? Presumably the BMS has shut down 12v charging because the main battery is low, by putting it into ready mode will this then start to recharge the 12v? and all is good , but you need to find a nearby charger. If not when you exit the car the ready mode disengages leaving the electrical power needs from the 12v or Noco . You disconnect the Noco and the 12v still has not enough humpf to power the car and it shuts down. So do you re-connect and leave it for a while or try driving to the nearest charger with it still connected. You will need enough 12v power to get the chargers to work. These boosters are mainly designed for ICE cars to give cranking charge to start the engine then the alternator will take over , so I,m guessing it will give a charge to the 12v battery but you might have to sit there for a while before disconnecting , I do not know, over to the experts and members who have more knowledge on tis subject.
