Tommohawk
- Jan 13, 2024
- Location
- Safety Bay, Western Australia
- MG4
Thank you
Would you be able link it or the name?Mine works fine with a wireless dongle, no cables.
There is no AA UI difference between wired and wireless. It is purely a connectivity capability.Also, does the UI or functionality change between wired and wireless? Asking if the dongle is just a connection or also some emulation happening.
Thanks for this. I actually ended up finding a cheap value pack of those flat cables at a red dot store, one being just 30 cm, so perfect length to feed through cable run without any slack. It works perfectly - play music and maps at all times. For me it's never been the quality of the cable, but the length. The shorter, the better. Just enough to get it to the ledge is what works for mine.I had a lot of intermittent connection with Android Auto over many rental cars and the MG4. It was never the car in hindsight.
But there is a difference between a working cable and a really good working cable, or so i learned. I finally said ill go against my understanding that i do use good cables, and i bought the cable with highest data throuput in gbps (10 gbps) i could find that had a usb c on one end and a usb a on the other, no adapters at all, and the shortest i could use (50cm).
It's been a week, with me using it all the time and stressing it as much as possible:
- always play music through AA
- always use guided voice navigation even if the trip is 10 minutes and i know where i am going
- have no locally downloaded maps
- issue all kinds of voice commands
I have had zero disconnects so far, so i was wrong for over 2 years - it is the cable.
Here's mine, outlining the important search terms:View attachment 37023
Hope it helps you not waste time.
However, once i got used to AA after must be the 20th attempt, now that it is reliable, the next hurdle is i don't like plugging in the cable every time. Us humans, we are strange that way i guess
So, now i am looking for a wireless option that is as reliable and as highbthrouput as the cable. Go figure.
If anyone uses one of the many stick linked here and can recommend it, i would be grateful.
Yes, I guess that's the difference in cable quality then. Glad you sussed it out. I'm happy with my solution as don't need a long cable. BTW, I had a Ottocast Wireless transmitter. Great for maps and music, but didn't function well with phone. Major delays in voice transmission and call dropping out. I do think there may be an issue with my usb port with this and the cable issue as I don't think anyone had this latter issue. Will ask for a check when I get 1st 2 yr service done in November. CheersThe cable I have that works is 1.8m!
I tried 2 cables before it worked.I believe the problem is usually the cable. I know your cable work at home etc etc but buy couple of good/very-good cables from google etc and then see if it still disconnects.
I'm not sure I follow - the MG4 doesn't natively support wireless AA, only wired. (Or wireless via a separate dongle). It doesn't have wireless AA hardware installed as far as I know.I have no idea why they can't get the software stable enough for it to work wirelessly as it's supposed to
To get a newer phone goes against the grain , I only use mine as a glorified MP3 player and its availability for emergency calls . Unless someone takes pity on me and suggests how to fix up a crowd funding site.........TBH, whilst A9 phones will still work they're way out of date as regards security patching. A16 isn't far off now.
A16 is already here, had it on my phone for a month.TBH, whilst A9 phones will still work they're way out of date as regards security patching. A16 isn't far off now.
I stand corrected, it shows how often I drive the wife's car!!I'm not sure I follow - the MG4 doesn't natively support wireless AA, only wired. (Or wireless via a separate dongle). It doesn't have wireless AA hardware installed as far as I know.
