Anyone using car battery to power house ?
Any ideas on where to get a V2L cable with the appropriate resistor and cable gauge and socket to enable higher discharge capacity?
Surprisingly I bought mine from Ali Express for $36.00 + $4.00 freight. Brand name Pecham. It is type 2 AC at 1 end with a universal 3 pin socket on the other rated at 32 Amps. There is no cable. I keep it in the granny charger bag. It was a bit of a gamble at the time but there were 2 customer reviews that said it worked with their MG4 & it does. I have only used it once at just under 2kW but the specification states output of 32 Amps. I have seen 16 Amp versions on Ebay with some comments (1 from a MG4 owner) that it didn't work but they got their money back.
15.05£ 64% OFF|Electric Car Side Discharge Cable Plug Ev Type2 16a Discharge Adapter For Outdoor Camping Electricity Charging Socket Outlet - Electric Vehicle Discharging Gun - AliExpress
If the mg don’t like it, it will trip out
I must admit that the MG4 is quite impressive - We're just going off grid - as am using the MG4 as a base load, while we transfer everything over - its very sensitive to resistive loads even as low as 0.5Kw at start-up, which is a good thing (once up and running it takes 13Amp + with no issues - We currently use a plug n 13A fuse, which is regularly checked for heat) - I should say that as most have noted is that, this is to charge the home battery for almost 100% of the time. If you own the car outright then no, but its its not yours then maybe.
Thanks, these don't appear to be available anymore.
Be interesting to see how much power you are able to draw.
Click on find similar items and the same brand is available from another supplier but at a higher price. There are also other brands but most are maximum of 16 amps.
One day when I get time I'll use my heavy duty extension lead to try and run a bunch of things to see what happens. I don't have the time at the moment. The blokes who did the test had all the right gear. I don't so it will be a bit of a guess.
I currently live off grid with a tiny house and use a 1600W array with a 10kWh lithium battery. I live in North East Victoria (Australia) so during the summer I have more than enough power but in winter I need to top up with a generator.
I’d really like to get an EV and top up from the EV and ditch the generator. I can charge the EV at local public charging stations - my array is too small to charge the EV. I know the MG4 does V2L but I also know the voltage is closer to 220 V than 240 V. I’d really like to know how well this arrangement works before I buy but I live in a country town with no EV rental companies nearby. My nearest MG dealer is 1.5 hours away. I did visit the dealer and plugged a hairdryer in with an energy meter which is how I know the voltage is a bit low. Some others have reported this online also.
Has anyone tried to charge a house battery from the MG4? Were there any issues?
I'm planning to do it in the near future, but don't have any expertise yet.
I think there are problems with earthing, but there are workarounds.
Yes, there are a few threads here from people who've done it.
This one from Terry, is a bit different and more than you need, but he's one of the relevant experts.
If you search here for charging house battery from car, you should find a few threads.
Apparently the low voltage isn't a problem.
Welcome to the forum. What voltage are your house batteries and what brand inverter do you have?
The Victron Multiplus and Multiplus 2 series have a low input voltage parameter setting that will handle down to 195 VAC, I know it charges the battery down to the 195 VAC and I believe it passes that voltage through .... judging by the length of time it takes the boil the kettle and cook toast.
The mains voltage in the Mannum area I'm in, must be tapped low to allow all the solar in the area to be absorbed into the grid, but on a cold evening or morning, before the sun starts to achieve much as far as rooftop solar, the grid voltage will drop below the 195 VAC threshold and the inverter will drop the mains supply and just run in inverter mode only.
The V2L adapter I modified and a 2.5mm² conductor 10 mtr cable holds the voltage up at 220 VAC, even with the rooftop rattler air con on heat cycle, the microwave running, the air fryer in full swing and still boil the kettle in a satisfactory time frame ....... while loading the system that high, the inverter dials back the battery charging rate, until the load reduces, then it returns to being a battery charger at a good rate, 95 amps in our case because the house battery is a Sodium Ion 12V 600Ah system and we programmed the max charge rate to 100 amps, up to 1.4kW, to leave plenty available for house power before the upper limit we have set at the moment of 3kW.
I'm happy to guide you through any set up issues you have, if you want me to, I did this stuff when T1 Lithium was up and running, but I've retired now, so avoid the hands-on work like the plague :LOL:
A good source for an MG4 EV battery set up, is to find a total write-off @ Pickles auctions. Plenty of info on here regarding getting unbricked ( After a frontal or serious side collision that activated the air bags, the main battery is isolated ... bricked just seems to be the term that caught on) and it will supply you with a heap of spares for your MG4 if you chose to buy one later on.
T1 Terry
Thanks for your replies. I believe my house batteries are 48V and I have a Victron Multiplus II 3kVa inverter. Your reply, Terry, has prompted me to reach out to my Victron dealer, Commodore, and ask them the question - I had not thought to do that!
See this test of using my MG4 V2L to charge our off-grid home battery using one of those cheap AIO inverter charge controllers.
The AC input voltage being on the low side is not an issue for these units, as long as it's in spec.
We've since moved home and I'm not using the off-grid system at the moment. I'm kind of hopeful I'll be able to use the V2L as generator input direct to my new system. It's not full operational as yet so I can't say.
I had used this a number of times as a supplemental charge source during long grid outages. Most I drew was 22 kWh one afternoon and night.
I had to plug the MG in this morning. No idea what went wrong during the evening/night/early morning, but the air con wouldn't turn on and the battery was down to 11.45v :eek: It is recharging at 90 amps now, give or take half a brick with other loads pulling the charge rate down for a bit, but the MG is putting out 4kw......
Found what the problem was, water heater looks to be on its last legs and corrosion from the aluminium back plate the thermostats are connected to, had reached the point where it touched the positive contacts creating enough of a short circuit to trip the RCDs. A hose-out with WD 40 and all is well again ..... but I'll enjoy my cup of coffee before I plug back into mains power ;):D
T1 Terry
Thanks for your replies. I believe my house batteries are 48V and I have a Victron Multiplus II 3kVa inverter. Your reply, Terry, has prompted me to reach out to my Victron dealer, Commodore, and ask them the question - I had not thought to that!
You can buy the interface from Victron to plug into your computer or smart phone and adjust the programming once you down load the app.
I can ask Margaret to give me a copy of which screens and what setting to adjust to get it running off the MG4 if you need it.
I'm about to look for a bluetooth dongle thingy to plug into our inverter, because I just finished building a box around it, so plugging the adapter box in is no longer a simple task :rolleyes:
T1 Terry
Not to dissuade you from buying the MG4, as it is an excellent car in its price bracket, but if you are looking at a V2G (vehicle to grid) setup for your home, perhaps looking at cars that are V2G ready would be more beneficial?
There aren’t many in Australia, but the Cupra Born is one of them I think, and then a ton of Audis and BMWs which of course have a different price tag. A V2G EV with a V2G charger should make life easier with an off grid system I would like to think. More V2G capable chargers are expected to come to market any time now.
The Multiplus II doesn’t have a dedicated generator input for the V2L to connect to.
If found the easiest (but not the most efficient) way to make use of the V2L is to top up the batteries directly using a dedicated AC to 48V DC charger (or a second Multiplus).
It worked a treat during an extended power outage in our area. Luckily the nearest rapid charger wasn’t affected, so I could top up the car (MG5) regularly.
It worked a treat during an extended power outage in our area. Lucky the nearest rapid charger wasn’t affected, so I could top up the car (MG5) regularly.
Connect a short lead from the Victron Multiplus mains inlet with heavy cable to a 15 amp wall mount plug.
If you are going on mains, plug the cable into there, if you are going to use the MG4 V2L, then plug that into the wall mount plug in point. If you want to run a generator, then plug that into the wall mounted plug.
This way, no two supplies can be joined to the Victron Multiplus mains supply at the same time, so no need for a change over switch.
T1 Terry
How does V2G help an off-grid system?
V2L can provide about 2-3kW of power, just about enough power to boil a kettle.
V2G is essentially rapid charging in reverse and requires an external, bidirectional EVSE.
Depends on the resistor used in the V2L, the 2k resistor limits the output to 2.2kW, give or take half a brick, 10 amps @ 220 VAC.
The 470ohm resistor allows the full 7kW to be drawn, but make sure you use a 5mm² conductor cable, 32 amps is approaching the limit for 5mm² over 15 mtrs of cable in open air, it would turn a 2.5mm² "15 amp caravan cable" into a smoking mess and the pathetic 1.5mm² conductor cable some try to sell as heavy duty, would probably catch fire. I have no wish to test that one ;) :LOL:.
The V2G requires a device to convert the DC direct from the battery into AC at the correct Hz and matched frequency .... and the approval of the local electricity authority .... over here, you would need to be right up on the electrical trading market to make it worth the effort .....
But V2L as a support for the house battery when off grid, brilliant and well worth the effort.
T1 Terry
