Archev
Distinguished Member
- Mar 30, 2021
- Age
- 76
- Location
- Borowstouness
- Not an MG
You’ve been told - stop picking it !! You’ll only make it worse ??Took it apartView attachment 13769
CT 1 ?I know what ct1 and ot1 is but bit lost on pt1?
I would make a written complaint to MG UK, the hinge looks like its designed to fail. It definitely is not fit for purpose.Took it apartView attachment 13769
it depends if you have the same plastic as diff plastics do not mix ie ppe and abs the super glue and bicarb works put super glue on and put bicarb ontop then re do againIt is technically possible to plastic solder it..... but still need to take bumper off![]()
Unfortunately the bumper will have to come off. Just paid my dealer to take off and put on the bumper about £350Has anyone attempted a repair or removal and strengthening of the door yet?
I bought a portable hot glue gun last week (would have to do this on the street) but due to the weather conditions have not yet even looked to see how the door can be removed, hopefully without having to remove the whole front.
Interesting solution for protecting the charge port door (you have to watch to the end or you can skip to 7.50 to see his solution. By the way its not an MG ZS EV but a VW ID4.
Well, we all know it’ll be cr-p then eh. ?Lol that's a ice car
I think the thing with 3d printing it is that it it will almost certainly be weaker than the original part. Even with perfect layer adhesion, the original injection molding will be stronger. If the original part design had weak spots it's going to be worse as a 3d printed part.If anyone has the broken hinge assembly, I can get it scanned (almost FOC) and make a 3d replacement at work.
I have been 3d print for 3 yrs no and if the part is designed and printed correctly (speed, temperature, type of filament) they can be as strong or stronger than the original part.I think the thing with 3d printing it is that it it will almost certainly be weaker than the original part. Even with perfect layer adhesion, the original injection molding will be stronger. If the original part design had weak spots it's going to be worse as a 3d printed part.
This youtuber does extensive strength testing.
