Charging Flap / Door not opening
I seem to have jinked myself saying the 51 has been problem free ..... can't open the charger flap now and we are 1600km from the dealer we bought it from ..... so I guess it's a phone around on Monday to try and find a dealer who can at least rip the outer skin off and give us an get out of jail free card to say it was a warranty problem.
I'm guessing rain and dirt has got into the solenoid and locking assemble because it is outside when charging as well as when we use the V2L, so I guess I'll have to track down some sort of rain/dust cover to protect it when the charge flap is open .....
T1 Terry
I bought a cover from Amazon. It has a magnet loop inside one end seam and a tie at the other. In an emergency (and it's not windy) cling film will do.
I read somewhere that unlocking whilst attempting to open the flap can work after a few goes.
Just checking. You don't know about the "manual" emergency method to open the flap? If not...
There's a small opening in the left sidewall of the boot which is covered with a plug that you need to pull off.
In the tube thus exposed there's a "draw cable".
Prise it out and then pull it.
The charger flap will open.
(Update) No it won't!
That's how you unlock a stuck charger!
Idiot Stimpy :ROFLMAO:
There's a small opening at the left of the boot sidewall which is covered with a plug that you need to pull off.
Isn't this just to release the charging plug?
Sounds like the spring loaded locking pin isn't moving when its released so unfortunately it looks like a trip to the dealers.
It might be an idea for those of us who haven't had this problem to spray the mechanism with silicone.
Yes I had this problem predictably in the winter when it iced up along with all the door locks, when it thawed out I sprayed the lock on the flap with silicone spray as well as all the rubber seals. That seemed to do the trick.
I've had the same problem, and temperatures here rarely drop below 6°C, so it seems like a possible common fault. Like others have said, I've found pressing on the flap in random places while simultaneously locking and unlocking the car multiple times with the remote will eventually free it up.
In frustration, I wedged the PO box key under the rear top corners and kept flicking between the locked and unlocked on the key fob .... no help, got my fingers under the white cap and applied a bit more pressure, still flicking between lock and unlock ..... and the door skin separated from the black inside door ..... and that opened with a simple push the same way the whole door normally opens.
The inside of the door skin has 4 tabs that appear to lock into the inner black plastic door ...... The skin is on the centre consul at the moment and the 51 is charging, tomorrow I'll look at it again and see what causes it to stick shut, ways to solve the problem, and how to put this door skin back on :LOL:
T1 Terry
When you think about it a fuelling flap, which is what we are talking about, might have been used once a week or even once a month in an ICE car. For an EV you could be using the flap 3 or 4 times a day for a longer journey. However, very few, if any of the manufacturers seem to have redesigned the basic mechanism to account for this increased amount of use.
There are a couple of other threads with details and pictures about this somewhere, one from @Bricktop X PWR I think.
But from memory, the outer skin is normally released from the black cover when it is open by levering a tab on the lower part of the black cover out with a penknife or small screw driver, and then sliding the painted cover in the direction away from the car to separate.
Refitting is just the reverse until the tab clicks back.
If it is jammed and the cover has been forced off while closed, you will see a large Torx bolt which can be rotated to release the inner cover.
Just a thought. If the outer skin became slightly unseated from its mounting on the black cover could it prevent the whole assembly being pushed in enough to release the catch?
As a first step, you could try relieving the pressure on the lock by pushing the flap in (gently) while locking/unlocking the car. And once you get it open, give the mechanism a squirt of a silicone based lubricant.
The more times the flap is opened, the more worn the locking mechanism would get ...... it wouldn't be getting stuck closed but rather not staying closes if the problem was accelerated wear and tear
The inner black door is the actual operating part, the cover is just decorative. If some of the tabs became unseated, the outer cover would not close to remain flush with the body ..... so I think we can rule that one out as well
Tried this for 15 mins, applying lite pressure closed on every edge/corner, the only win was applying pressure to the top rear most corner, where the flap actually opens ..... this gradually resulted in the cover coming off, then the inner black door opened easily, a light press and it popped open.
Tomorrow I'll look at the possibility it's dirt collecting between the outer cover and the rubber seal, not allowing the inner black door to move inward to release the clatch on the locking mechanism so it can spring open .....
T1 Terry
    Votes: 971 77.7%
    Votes: 185 14.8%
    Votes: 93 7.4%
