GranTurismoEra
Where did you get it done?When they did the update they said some European countries don’t have R34.
The dealer had to do the upgrade via another module not directly to the infotainment system.
When I try playing this test via my iPhone and a cable I get nothing during the subwoofer test.
Do others get any sound during the subwoofer test.
Get a list of what the update fixes including the MG Pilot options that apparently let you save some settings maybe. Then tell them you want those fixes. Or try another dealer.I've just had a door proximity sensor replaced; when dropping the car off at the dealer I mentioned my disappointment with the sub-woofer, so they performed a test and they say it's working. I have the R31 software but they won't update it unless they agree that there's a problem.
When I try the test at this point I do not get any sound. Try it and if you get no sound show your dealer.I've just had a door proximity sensor replaced; when dropping the car off at the dealer I mentioned my disappointment with the sub-woofer, so they performed a test and they say it's working. I have the R31 software but they won't update it unless they agree that there's a problem.
This is great news! Can you share some more info about what MG location made it work? MG the Hague was not kept in the loop and needs some more info to help my Cyberster outFinally, it worked.
After the sixth attempt, a specialist from MG Europe managed it.
This guy had the latest software, as well as the latest equipment (tablet and wireless transmitter) to download and upload/install it.
Now the version R34 software is finally installed, and I have to say, the sound has improved considerably.
The rear speakers are now audible, but not intrusive.
You're now more immersed in the sound because it's coming from all directions.
Everyone's happy again!
May I ask what exactly the "MG pilot custom" includes?Hi I have my Cyberster since December 2024 and recently got the software upgraded from R31 to R 34. I was also told initially by the dealer where I bought it that it wasn’t available in Ireland but subsequent enquiries directly to MG Ireland said it was possible so I arranged to go to a different dealer and advised them to check with MG Ireland which they did and carried out the upgrade with no issues it took 2.5 hours. The MG Pilot custom is now available to use but I didn’t notice any change from rear speakers.
Hi I also bought mine at Frank Keane who were also unaware of any software update.Thank you, which dealer did you bring it to?
I bought mine from Frank Keane (I wouldn't buy from them again), and they told me there was no software update.
We all hope for a happy ending to this scary adventureMijn Cyberster is momenteel in de garage voor onderzoek (bij de dealer in Richmond). Ik heb melding gemaakt van een probleem met de luidspreker en ook van stuurcorrecties, zelfs bij het afslaan met richtingaanwijzer. Die stuurcorrecties zijn erg vervelend, omdat ze gebeuren bij de kruispunten die ik het vaakst gebruik. De enige manier om ze te stoppen is door de rijstrookassistentie uit te schakelen. Ik heb een van hun monteurs een voorbeeld van de stuurcorrectie laten zien. Ik hoop dat MG UK een upgrade van R31 naar R34 accepteert. In het ergste geval kunnen de geconfigureerde rijhulpsystemen in ieder geval snel en eenvoudig worden uitgeschakeld met R34; en misschien is er dan iets meer bas uit de luidspreker. Idealiter wordt het stuurcorrectieprobleem opgelost en is er een fatsoenlijke bas. Ik laat jullie weten hoe het afloopt!
