EON Next Flex Drive
rigby44
NW England
Hi guys,
Just thought i’d make people aware, EON do have an EV tariff, though they are quiet about it.
Bullet points:
7 hours of low rate charging (10p/kwh) between 12am-7am
Works with any EV. You need usual smart meter etc.
Rate outside 12-7 is penal, 43.7p/kwh compared with Octopus Go at 31p. Of course you benefit from the additional 3 hours of low rate charging from Eon over Octopus Go. Standing charges are the same.
Would anyone estimate that this is ‘much of a muchness’ in terms of the higher day rate cancelling out the additional 3 hours of low usage? Thanks to a kind MGEV forum member i’d also bag £50 credit if switching to Octopus Go.
I'm on 'Go' and think I will stick with that.
Currently I have 7.5p overnight until September (fixed period) when I think it will raise to 9.5p. Day rate is cheaper as you say but that doesn't worry me too much as I have a battery on my house.
Octopus allows me to manage my bills efficiently and after recent discussions with them, they have updated their portal to allow more efficient balance withdrawals and over payments along with direct debit adjustments made online under your control.
Not sure what EON offer in competition, but their offering above doesn't tempt me.
Not sure what EON offer in competition, but not their offering from the above doesn't tempt me.
Thanks, yes being quoted 9.5p as a new customer today by Octopus.
Octopus will definitely be nicer to deal with, with more control over the account - Eon are one of the ‘old guard’ and their move to digital has been quite poor.
If you have an Ohme EVSE charge point then you can get 6+ hours at 7.5p.
Yep intelligent octopus is really good and 6 hours gives 40+ kw , so 60-70 % charge. Also if you leave your car plugged in and octopus have low demand they will charge your car outside of cheap rate at the cheap rate price, just need the ohme which works well
I'm on E.ONs EV tariff which suits me as I'm usually up just before 6 (benefit? of having dogs) and have an electric shower so can use that on the cheap rate as well as put a wash on if I forgot to set the timer the night before.
There is also no contract so no penalty for leaving and I'm just letting the energy market settle down before I look again at my supplier again.
Hi Ian, i’ve just taken Eon’s tariff. They’ve put the gas down from 10p to 7.5p so bit of a saving there too.
Would you say you are being badly impacted by the 43p daily rate, or not so much? I know i’m comparing apples with oranges, but we dont have electric shower or hobbs so hoping it wont ‘hurt too much’.
Octopus IO can't be beaten for me 6 hrs at 7.5p rest at 29.8p and gas is 7.5p
As you say it's comparing apples and oranges. It depends how much electricity you use on the day rate and I might still change suppliers as there is no penalty in leaving E.on. I'm just waiting to see what happens in the next few months and if Octopus and Zappi get their act together.
Im with british Gas . Gas is 7.39 with 29p standing charge. Electric is midnight to 05 is 9.4p and day rate 3.89p. 41p standing charge It should be 38.97 day rate but they are charging me the lower rate someone got the decimal point in the wrong place . This was confirmed yesterday when an engineer called out. He just said to crack on its a bargain .
Anyone got referral code for E.on for £50 voucher?
I've just changed from BG and was considering Eon. Didn't try on here but no one on another of my interest forums had a code either which might say something. Was not convinced when I phoned them either. Octopus appear far more switched on (hope you see what I did there :) )
My ev tariff with BG coming to an end too...Octopus is more expensive for me than others, it looks like it depends where you live...
E.on is just a touch cheaper than BG for me (saving of £50 or so) but it's got 1 hour longer off peak which is slightly better for me with my granny charger... 🤷‍♂️. Got the code from another friend in the meantime..
I've just gone solar so bit of a curve to understand whats going on. Advised that SEG was most straightforward under Octopus. BG wanted you to send queries by email which they did not reply to and Eon were going to take 2 weeks to do things that Octo did in a few days.
Wasn't life simpler when there was one gas and one elec supplier :)
Yes .. I was also thinking about solar and home battery, and new EV charger and ... And just gave up for the time being... Need more time to figure it all out but want to avoid these price rises in October...😵‍💫😅 (unless I'm already too late)
You could always let a big company like Octopus or heatable design
My recommendations would be...
1. get as many panels as you can fit on the roof (it is easier to add a battery in the garage than panels on the roof with scaffolding)
2. Get the bird proofing.
Loads of people on here and elsewhere can give you feedback on quotes.
    Votes: 1,049 77.8%
    Votes: 204 15.1%
