The problem with that is it is fixed in a position with the cable in place, with the plug permanently exposed at the roads edge, and it requires that you are able to park in exactly the same position each time.On closer inspection, looks like it can be bolted into the pavement - that should reduce any tripping hazard.
Also, just saw this guidance note...
Time to elect different councillors methinks!My local authority won't allow it
Not surprised. I'd imagine it would be a can-of-worms, liability wise.My local authority won't allow it
Actually I guess it is very hilly where you are so that complicates things a bit.My local authority won't allow it
Any chance of lamppost or other on-street chargers
The problem with that is it is fixed in a position with the cable in place, with the plug permanently exposed at the roads edge, and it requires that you are able to park in exactly the same position each time.![]()
Cool - and you get to hang the hoodie cycling on the pavement at the same timeI know there will be more expense involved, but would a Chargearm work for you @fishfinder125 ?
Cool - and you get to hang the hoodie cycling on the pavement at the same time![]()
Anything proud could trip a blind person, elderly person or infant. The highway authority (usually the council) has to approve your individual solution but some enlightened ones automatically approve certain available solutions. Check out Charge Gulley and Kerbo Charge.To be on the safe side, as said check with the Council. If they say it's ok, then that set up, you've got, is fine. Unfortunately you can't do owt, about arsehole neighbours moaning.
Or alternatively, just do it, coz personally, to me that looks fine. I've seen I few of them, and you'd have to be a dozy Git, to trip over that.
It's up to you.
That's really clever. One thought occurs to me as just this week we had the pavement dug up by Openreach for next door's landline problem. Would the contractors put it back?You could try these guys, nothing to lose :-
Kerbo Charge - EV Charging Cable Channel | Charge Without a Driveway | As Seen on Dragons' Den
Charge your EV at home with Kerbo Charge. Our safe and secure charging channel has a self-closing lid and is council-approved. As seen on Dragons' Den.www.kerbocharge.com
