100% agree with
@Everest .
When a high current is being drawn over a long period of time, heat is obviously generated here.
Then the live contacts on fuse carrier start to become weaker and weaker over time.
As soon as this starts, the deterioration is fast and very easy to over look.
This is when it becomes dangerous.
It can go from being fine for months, then in a very short time, fail dramatically !.
I used a granny for only 6 months, while waiting for our wall box to be installed, along with a 100Amp upgrade in our main cutout fuse by the DNO.
This was on our 2015 Golf PHEV with a small traction battery.
But every single week I would go to the plug
and pull it out.
Checking if is was tight removing the plug, then any brown staining on the socket outlet and condition of the three pin plug on the OEM granny.
The charging socket was on a dedicated circuit and protected by a trip.
A bit “over the top” I accept that, but it pays to be over cautious I think.
This type of problem is not just limited to granny chargers of course.
Even wall boxes can suffer from heat / burning due to poor terminations / connects or component failure.
I have had two Rolec OEM RCBO units fail in our wall box, due to over heating.
Not connections issues, but poor quality RCBO’s that only lasted about 18 months each.
