Home charging - Does it stop costing £ once car is fully charged?
Martyn2909
Gosport, UK
MG4 SE SR
Scenario - I am charging my car at home. The car becomes fully charged at 2am. The car remains plugged in until 7am...
Will the 5 hours (2am-7am) still cost money even though the car is fully charged or does the costing stop at 100% charged?
EVs typically switch to trickle charging once full
They don't switch to trickle charge but they do switch to what is known as a balance charge if the BMS deems that is required. This will equalise the charge on every individual battery cell and may run for several hours, but only at a load of a few hundred Watts. When this is complete or if the BMS decides it isn't required, the charger will disconnect.
My experience agrees with this - and once the balance is done the car tells the charger to stop and no current is then drawn.
I did a charge from 50% to 100% last night and it looks like the car was performing some balancing for around half an hour and then it has completed the charge. Here’s a screenshot of the Zappi charge history.
    Votes: 948 77.6%
    Votes: 181 14.8%
    Votes: 92 7.5%
