How Low Can You Go .... (SoC)
siteguru
Distinguished Member
Solutions
3
Strathaven (SE SR MY22)
It's GOM calibration and balance time, so I ran the car down low and left it for a couple of hours before starting to charge. This was a photo I took immediately before starting the charge:
Anyone else gone lower? :)
PS - I checked the SOH with Car Scanner and it said 92.66%. I'll check again once charging and balancing is all done.
Do you do this from your own data? I’ve never let the car run below about 5%, and just charge it to 100% as and when I need it, which is usually twice a week, and usually from 50-60%.
I could probably get to two% driving round the estate, but I would want to be coming from very far.
That's what I was doing, pretty much. I went for a drive around, and finally to the nearby village and back ... the uphill stretch coming back from the village had my buttocks clenching when the power started to limit ....... 😱 I made it home OK though 😂
My lowest so far is 5% and that had me a bit worried. I tend to charge now at about 20% but certainly no lower than 10%
S'pose it similar to driving on fumes in an ICE car, looking for a garage. Although I can imagine it would be a bigger pain in the Ass. To to run out of charge in an EV.
Than to run out of fuel in an ICE car. 🤔
Less of a pain than running out of diesel in a vehicle that needs bleeding.
You could always carry an eco-flow (or similar) like Bjorn does in his range tests to recharge.
Or, better still, just post a "yelp-for-help" on this forum and I bet someone would get you going with their MG4 and V2L lead ;)
Do modern Diesels need bleeding?
Anyway, EV or ICE it would be be a Pain.
Out of curiosity, has anyone run out of charge. What did you do? 🙂👍
Nope not like they used to with a priming bulb and mechanical injectors. Fuel is constantly pumped and circulated in the common rail which feeds the injectors. Interestingly that’s why you should keep the tank with a decent amount of fuel in as it needs to lose the heat in the return to the tank.
Reminded me of the Ford focus I ran a decade ago, I had a gizmo wired in-line with the common rail pressure sensor which 'tricked' it into running higher pressure thus giving more power.
Fine for a good couple of years until one rainy January evening at 60 mph I heard a faint 'ping' and the engine died immediately thereafter. Flat bed recovery after waiting 2 hrs freezing to death ☹️
After much head scratching investigation, turns out that there was a tiny hairline crack in the cast metal common rail itself, clearly had enough of the increased psi after 24 months of abuse.
Regarding the 4 SE, I've ran mine to 0% and it still moved for a further mile before I scuttled for home and charger, just wondered what happens at zero :unsure:
I’m pretty sure RAC here in Perth has one or two EV-rescue vehicles that basically carry a (fast?)charger with them in the van and can charge you road side, but I don’t know what happens if you’re out of the city. Maybe they send out a truck with a generator?
I always have my granny charger with me, if it ever came to it I would just find myself a house and offer them some cash to charge for a few hours. Not great but better than nothing.
PlugShare shows you some private chargers too come to think of it, that would be better than a granny charge.
Unless you know someone nearby who has a 50% charged car with V2L, and you have time to spare. An hour would give you around 3% which may be all you need to limp home.
Nop. When my diesel Merc goes into 'Reserve' amount of fuel I still have 108 miles of range left .......
Our UK lot have whacked big alternators into some of their recovery vans so they can up their idle and pop a little charge in to limp people to a charger.
    Votes: 1,052 77.9%
    Votes: 204 15.1%
