richlove
- Feb 27, 2023
- Woburn, Bedfordshire
- MG4 (2022-2025)
I'm going to try this tonight. If I set the scheduled charge time (00:30-04:30 for Octopus Go) in the MG iSmart app and send this to the car, when I plug the granny charger lead in, will it not begin charging as usual, and wait until 00:30 instead?I have a Zappi, but I've just set scheduled charging in the MG software. One annoyance is the MG4 sometimes decides to start charging so you have to double check it doesn't. I've also seen it decide to reset 80% to 100% and I don't know the reason.
At the moment, it's failing to send the scheduled time command to the car, though it may be because there's not much signal for the car to pick up.
Also, does the car remember the scheduled charge setting from here on following charges/days or do you have to resend the scheduled time command each charge?
