Immediate Range Drop
Brucey7
Chiang Rai, Thailand
Ny daughter’s MG4 SR is almost 2 years old, fully charged it reads 405km range, within 10km it drops to 335km range. Battery SoH is 92% and outside temperature 25°C (we’re in Thailand).
Is this normal behaviour? It didn’t do this a year ago.
Has your accumulated total reset perhaps? After 99.99 hours the range prediction resets itself, making the range appear as near as WLTP range as it gets. By driving the range adjusts to more accurate numbers.
What range did she normally get before this started happening?
I think it used to display 430km immediately after charging, but it dropped normally as you drove.
The issue now is it shows 405 km after charging but within five or 10 km it drops to 335 km, after that the drop is in line with the driving distance.
I was wondering if there is a problem with the battery that is not shown by the dealer checking SoH.
The WLTP range of an SR (51 or there about kWh battery pack, correct?) is 350km. So if she has an SR then a range of 335 km is what one should expect.
Perhaps in Thailand the battery pack is 64 kWh, which should give between 435 km (with spoiler) and 450 km of range. So the 430 km could be showing after a reset (when the car assumes you will do WLTP) and then drops when the car realises you’re driving like a normal person and not on some test track.
It is really hard to determine what causes an adjustment to the range. Weather, driving style, use of a/c or other things like charging a laptop, high driving speeds, going uphill… the list goes on.
Perhaps she can drive the car down to below 10% charge, leave it there for an hour or so, then charge to 100% and let the car balance (the car should do this automatically if you just leave it plugged in after completing the charge). Every now and then the car needs to see the bottom of the well in terms of the battery to more accurately predict what the car can do.
It could always be a deeper issue, but try these steps first as they are the strange things we never had to do in ICE vehicles.
    Votes: 1,096 77.7%
    Votes: 212 15.0%
    Votes: 103 7.3%
