Andrew Sinclair
Mine is working, v2.0.4 iOS 17.2.1
Unlock/lock the car it wake it up and restart the app.Is the iSmart app working for anyone today? I have not had it connect to the car since mid day today. I'm on the latest version, it worked till late morning and ever since hasn't worked.
Same !.Mine is working, v2.0.4 iOS 17.2.1
Same here - working fine !.App is working fine for me on iPhone
Mine did the same thing, so I ran the scan which checked everything. When I tried again it started to defrost.A real pain this morning frost on windscreen . That’s good use the app from my iPhone to defrost the front windscreen
Again try again later it’s about time Mg sorted it out
Has anyone else had the same trouble or is the app so bad that it can’t be fixed
I’ve just checked mine, and yes, EV stations are being shown! The app is gradually becoming more usefulOooh, out of the blue mine now lists some local EV stations... Instead of shanghi... its the first time its done that.
I'm using my mobile number as my username and this seems to be accepted but I then get the prompt to bind.Are you using the mobile number (no zero) or email address that was originally used to set up the account? This seems to be the source of many problems.
Where did you find the earlier APK Version of i-SmartI had exactly the same problem with android 8, even though play store said my phone was compatible. I ended downloading the APK earlier version of iSmart, disabled auto update and seems to have cured the problem. HTH.
Barney
