Scody
The same thing happened to me. How do I delete the accounts and reinstall everything fine? Help thanks
Exactly what I've been saying for agesTherefore, my car was already bound to my account because I must have used the phone number login when I originally bound the car with the old app.
Once you've first logged in via your original login, you can subsequently use either method. (At least I can).MG do not make it clear that you have to stick to either email user name or mobile number user name, otherwise you create two accounts.
Me, I have no issues to bind the car. As I said in an another post, it looks like the privacy settings make some trouble but everything is checked on the car settings.Hi, my TBOX was replaced because of mainly 2 things: intermittent connection issues causing the SOS and ecall faults ; secondly the GPS in my car was not working, the navigation was always showing the wrong location or static at one place.
After swapping the TBOX, the GPS is working fine, but the app is not scanning the QR code now. I know I should not have unbind the car which was my mistake.
When I try to bind the car now, It always says 'service is not available, please try again later'. I am not sure if this issue is due to the new Tbox or the new app. The dealer is saying it is due to the new App and asking me to wait for new a update on the app as MG is working on it.
I can't argue as the timing of new TBOX and new app exactly coincided for me!
I (already) got a feedback from technical supportHello. So far, nothing. It's only 2 days now.
I'm waiting some news from my dealer and send a mail to MG tech support ([email protected])
i'm so frustrated...
Your TBOX was swap for the same reason ?
You and your wife should not have different accounts - you should use the same account details on different phones and then it will switch over, logging the other one out when one logs in.Yes I know. But my wife account was never bound to my MG4 before I try friday (and unbound just after), only my account and I just share the digital key with her.
But since then, only my account was bounded, and nothing keep working...
She never uses my car. She only needs to get access when she arrives at the car first.You and your wife should not have different accounts - you should use the same account details on different phones and then it will switch over, logging the other one out when one logs in.
I don't believe the car supports multiple personal accounts.
I have an MG4 and have also struggled with new software binding and unbinding. Today, result. I logged on using my phone number (without zero) rather than my email. Must have done this at the start. Bingo.Hi, my TBOX was replaced because of mainly 2 things: intermittent connection issues causing the SOS and ecall faults ; secondly the GPS in my car was not working, the navigation was always showing the wrong location or static at one place.
Hi,Since the upgrade of the iSmart app before Christmas, I have been unable to Bind my MG ZS EV. I have deleted and reloaded the app, Switched my iPhone off and restarted all to no avail.... Any ideas would be gratefully received....
Is your display set to "auto" or "dark" mode?Hi,
I am unable to bind the app to my MG4. I can the QR code and it says success but the screen on the App remains the same with the blue bar saying 'to bind' following the app update. I have been doing this on and off for nearly a month now. I have checked and am using the same email address as i originally used. Beginning to think its destined not to work for me so any thoughts/suggestions would be gratefully received.
If it's a brand new car then follow what @WonkoTheSaneUK is saying; if it's an existing car and you're being asked to bind after updating the app then follow what @Martinonline is saying.Hi,
