bloggsy
- Feb 27, 2021
- Edinburgh, Scotland
- ZS EV
Hi @JodyS21 - the LED's should be at the 3 and 9 o'clock positions and, in my case, the wire from my unit faces down towards the ground. However, I needed to rotate my headlight bulbs slightly so both light/dark lines on both headlights lined up, horizontally!The new led bulb, on dipped, no matter what, when I turned it (the housing that rotates inside the collar locked into the socket), always gave a nice horizontal line at the same place. But it will won't it, as it uses a moveable bit to block the light, so I don't quite know how to tell if it's lined up?
The light pattern on the ground infront of the car changed a bit as I turned it, but how do you know what it right?
Should the bit with the actual LEDs on it be vertical, such that the LEDs on either side are directly on a level horizontal plane? When it is like this, the wire coming out of the housing is either directly at the top or bottom?
I hope this makes sense!?
I never really bothered about the height of the light and just assumed it was okay and, to be fair, I can see the line in the windscreen of oncoming cars and it's below head height. That and having never been 'flashed' by other car drivers, has confirmed my headlights are correctly adjusted!
Hope this helps - it's a shame you're so far away as I could've met you and adjusted your lights.
Cheers
Bloggsy
