Yes it comes and goes sometimes, yesterday I had a little when I drove in one direction, but on my way back it was gone again. It's my first car with roof bars
Had some nasty crosswinds over the last day or so on my commute. Also noticed that there was a noise coming from the area around the door. But only when the wind was gusting passenger side to driver side. I'm just wondering if the door is flexing ever so slightly under those conditions, exposing the seal.
The door seems sturdy enough. I will try to experiment with putting some tape over the hole in the seal that I found (+ a lot more ) but I will only try to block one hole, I understand the reason why they are there. The hole I showed in the picture fits exactly with where I am hearing the wind wizzle coming from, btw. I don't feel any draft, so I think the wind get caught in the hole and play a tune.
For anyone with a Panoramic Roof the adjustment of the glass alignment should be such that the leading edge of the front glass is a fraction lower than the car roof. The trailing edge of the rear glass should be a fraction above the car roof.
A fraction being around 1mm.
This is to avoid Lambda airflow turbulence, if they are not correctly adjusted it can affect the wind noise considerably.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
