Main screen dimming
sg2808
Reading
MG4 (2022-2025)
The main screen does not dim to a minimum at night, even if my setting is at minimum. I have to go to the setting and then just fiddle with the settings a bit and then it turns to the minimum.. have you all faced similar issue?
I think there's a bug when you push the slider all the way down to '0%'.
Instead you keep it a touch to the right - 'at 1%' - that should do the trick.
    Votes: 1,084 77.8%
    Votes: 208 14.9%
    Votes: 103 7.4%
