Main screen dimming
sg2808
Reading
The main screen does not dim to a minimum at night, even if my setting is at minimum. I have to go to the setting and then just fiddle with the settings a bit and then it turns to the minimum.. have you all faced similar issue?
I think there's a bug when you push the slider all the way down to '0%'.
Instead you keep it a touch to the right - 'at 1%' - that should do the trick.
There also a bug when reversing and it screen can go full brightness, most unpleasant at night.
    Votes: 1,013 77.9%
    Votes: 191 14.7%
    Votes: 96 7.4%
