Well, we've decided to get panels and batteries installed.
Our house is south facing semi-detached in sunny Gosport.
Any advice?
Any advice?
My 2p worth...Any advice?
Very good idea!Well, we've decided to get panels and batteries installed.
South Coast - best place in the country for solar!Our house is south facing semi-detached in sunny Gosport.
Get three or four quotes, as with most things.Any advice?
I'm withVery good idea!
At least one from heatable. They offer some 0% finance deals, but selectively.
Octopus could be worth a shout and you can find one or two local MCS approved providers.
Fill up your roof, as @Everest says.
As you've got 2x EV you can't really have too much. If companies drop their export payments you can just dump it in the cars for free driving.
Get the bird protection.
Your decisions are:
Will you be getting a heat pump? (We all need to at some point). Bear in mind this will greatly increase your winter power usage, so you'll want more solar and battery for then.
- String (probably cheaper) vs. micro-inverters (better if you've got roof that faces in lots of directions or has shading, seems that T1 Terry isn't a fan)
- DC-coupled battery (better for efficiency, but tend to be lower output which might not cover your load if you have lots of things running at the same time) vs. AC battery (less efficient, more expensive, better for backup power)
- How much battery capacity? Over 9kwh is recommended, but 5 is a lot better than nothing. It is usually easier to add on more battery than panels, given the scaffolding need so if you've got a budget fill up the roof first and then spend the rest on batteries.
Me neither, unless there are mitigating factors. Cost of adding battery capacity becomes much more expensive with micro-inverters and you have no capability in the case of power outage.
a) Note to self... must book in with spec-savers
Those with micro-inverters would just go with a separate AC-coupled battery, though, right?Me neither, unless there are mitigating factors. Cost of adding battery capacity becomes much more expensive with micro-inverters and you have no capability in the case of power outage.
Maybe I'm out of touch on that one.a) Note to self... must book in with spec-saversNot sure why you say DC-coupled (i.e. hybrid) tend to be lower power? Do you have some examples of that?
Probably for the best, sadly!Further thought... probably best to avoid Givenergy-based system after @Bam Bam's recent experience.
A heat pump is going to work in any house, though it will have to work harder (ie you'll need a bigger one) to recapture the heat that a poorly insulated house is losing.I'm withand getting quote from them
Heat pump no as my house is 97 years old with suspended floors
And we got a new boiler last year
Yes, but won't offer the same capabilities and works out more expensive. If there is a power cut, the batteries won't get charged because the micro-inverters will drop out due to no AC grid.Those with micro-inverters would just go with a separate AC-coupled battery, though, right?
I see. There are many hybrid inverters with greater power output though. e.g. Solis, Sunsync etc.Maybe I'm out of touch on that one.
For Givenergy the AC coupled option offers a higher discharge rate than our hybrid does. We've got a 5kw inverter but you only get that output when the sun is shining. The battery on its own only offers 4kw.
Other companies might offer hybrid systems with better outputs. I suppose it depends how it is set up.
Wouldn't the backup system create a local AC microgrid?Yes, but won't offer the same capabilities and works out more expensive. If there is a power cut, the batteries won't get charged because the micro-inverters will drop out due to no AC grid.
The AC coupled storage inverter may have an AC backup, but it would not be connected to the AC-grid connection that the micro-inverters are connected to.Wouldn't the backup system create a local AC microgrid?
However, IMHO, you should never connect a generating supply to an inverter's backup output.
Inverters will constantly attempt to push the phase by injecting a small frequency shift to the supply to detect if they are still connected to the utility grid. As that is not possible to increase the frequency of the national grid, they know they are still connected. If connected to a locally generated back-up source they may or may not be able to adjust the frequency. If they can't adjust the frequency of the Powerwall, they may be tricked into believing there is a local grid island.
BUT... grid-tied inverters are designed to run wide open at all times - without any control, or somewhere to send the power (the grid, usually - possibly the batteries in the PW until they are near full), they would just damage anything connected to it. Once the grid-tied inverter pushes current to a limited source that cannot take it the really bad day begins
Same. Would have been cheaper to get it done up front.Fully agree I had to retrofit it to mine.
A couple of harmless shots with the NERF gun soon discourages them.Same. Would have been cheaper to get it done up front.
Plus we still have pigeons hanging around our roof because they often hang out wherever they were born.
