MG HS Hybrid battery drain
Good morning.
Yesterday, they finally delivered the car. A technician came and installed new software. The screen now turns off when I lock the car. We'll see how the car performs over the weeks.
I'll keep you posted...
I am a bit confused, my dealer said that there is still no software update for this issue.
Even if I am in France, I don't think my car is different than a spanish one.
Good morning.
What was the version they installed on yours?
Mine is the SWI136-29958-1100R58.
This is the thisrs time my battery dies in 9 days. I've jumper-started it now and noticed that the dashboard backlight is in fact always on.
After jumper-staring it now my dashboard show errors for asll driver assistances though.
This is my locked car last night after the last jump start. This morning the battery was dead again. Did another jump start and went straight to the MG dealership in Seville.
They seem to know about this issue and that a "reprograming" will be necessary. We scheduled it for monday at 7am. Let's see...
Same here. HS PHEV TROPHY. Picked up 22/6/2025. Back at dealer due to three flat batteries. Something is draining the battery when it's stood with ignition off. A faulty component no doubt.
Same problem here. The cause of flat batteries on 2026 MG HS PHEV is the fact that after switching the car off the screen directly in front of you has a backlight and this stays on draining the battery. You can only see its on in the dark. Mine is going to MG tomorrow for a fix.
They did a software update that didn't fix the problem. They then said the screen needed to be replaced. I waited 7 days for them to arrive and the service took some 3 hours. I can confirm this finally fixed the problem.
New to MG but reading the problems of 12V battery drain has left me feeling have I made the right decision to go with MG. I have a MG HS hybrid+ have had it 4days. Do members have experience of the same problem on the HS and has the problem been sorted for the members affected.
Sounds like Parasitic Battery drain, which my new car September 2025 had, rejected the car Jan 2026 and got full refund. First I was told I wasn't driving it enough, then they updated the software. happened again they agreed I wasn't going mad and there was something wrong with the car. They tested the 12v battery and it was fine out of the vehicle charged and held charge. In the car battery drained, no matter how much charge was being put into it. They described it as a module (didn't know which one) not shutting down. TBF they refunded without an issue.
