MG ZS EV - I cannot use CCS On Public Chargers
I'm on my first long run in over a year (Doncaster to Tenby) and am having problems at public chargers. I charge once or twice a week at my home PodPoint charger with no problems. I've now been on the road since 05:00 and it's 11:33 and I've tried two different public chargers ( BP Pulse and Genie Point). I'm having the same problem at both chargers. When I try using CCS I pass all the connection tests but they fail to give me any charge. I've contacted both tech admins and they've rebooted the chargers several times to no avail. I've then tried the Type 2 connections and they have both connected and charged. Has anyone else had this problem? I have a MG ZS EV Exclusive and it's red if it helps.
I've had no issues with CCS chargepoints (I've 2020 zs EV)but do ensure the cable/connection fully engaged. I've generally found push/pull/push works.
This happens often to me at our local 50kW InstaVolt, it connects to the car and reads the mileage and battery percentage, then says charging and a minute later it says not charging, I can give up and go back the next day and it will charge. I don’t do anything different so I don’t know why it charges sometimes and not others. It connects every time without fail at Tesco 7kW pod points.
compatibility with MG4 is sketchy on ccs, had good times with instavolt and Tesla chargers. Try to stick to those for now
I use Podpoint and have used both CCS and type 2. Seem to be reliable and reasonably priced.
I'm just about ready to set off home to Doncaster from Tenby and I've charged using CCS several times and I think I've cracked my charging problems. It doesn't matter if the car is on or off, locked or unlocked, Red or blue. What you need is a handful of chicken bones. Whichever charger you use either plug in first or get the app working before plugging in then throw the chicken bones onto the floor. Then the charging will start or it won't. Simples.
So do you take the chicken bones with you or can you only charge at KFC after eating a bargain bucket ?
Yes i am in the same boat> I had my car for almost two years and it only works from the home charger.Tried in Calais yesterday and at the hotel with no joy.Soooooo frustrating.
Are you saying that you can't use fast chargers for the past 2 years? Why haven't you requested MG to look it up under warranty?
We had a problem in Tasmania with fast charging, only once though. Most times it has worked when we needed them. The one time the fast charger would not work, I tried holding the plug up to make sure the communication pins were connecting. No go, I gave up after about 5 tries.
When we got home I disconnected the 12 volt battery for 10 or more minutes. The next time I tried the fast charger it worked fine. I rarely use fast chargers and never have problems charging at home using our Zappi or any other home chargers
Ours is a Gen 1 ZS EV
Pete
Pete
If one charger fails to charge it may well be the problem with that charger and not the car, I would not disconnect the 12v battery for that unless at least 2 other locations (not chargers at the same location but another location chargers) also failed. It happens sometimes for no clear reason...
I get where you are coming from Fred, But where I live it is different. We live 38 kilometres from the town where there are fast chargers. We charge at home off our solar system, but in town there are only 3 fast chargers at the moment. Driving about trying other chargers is not easy as they are often being used. So I have to try whatever solution works at the time. It may be that it was a charger fault, but there was a company representative there at the time and he could not get it to work either. He said that they often have problems with MGs and Volvos not being able to charge.
Pete
