CatalinCazacu
- Feb 17, 2023
- Swindon
- MG4 (2022-2025)
I think might be worth a try to Ionity or Tesla.
I've had no issues with CCS chargepoints (I've 2020 zs EV)but do ensure the cable/connection fully engaged. I've generally found push/pull/push works.I'm on my first long run in over a year (Doncaster to Tenby) and am having problems at public chargers. I charge once or twice a week at my home PodPoint charger with no problems. I've now been on the road since 05:00 and it's 11:33 and I've tried two different public chargers ( BP Pulse and Genie Point). I'm having the same problem at both chargers. When I try using CCS I pass all the connection tests but they fail to give me any charge. I've contacted both tech admins and they've rebooted the chargers several times to no avail. I've then tried the Type 2 connections and they have both connected and charged. Has anyone else had this problem? I have a MG ZS EV Exclusive and it's red if it helps.
This happens often to me at our local 50kW InstaVolt, it connects to the car and reads the mileage and battery percentage, then says charging and a minute later it says not charging, I can give up and go back the next day and it will charge. I don’t do anything different so I don’t know why it charges sometimes and not others. It connects every time without fail at Tesco 7kW pod points.I'm on my first long run in over a year (Doncaster to Tenby) and am having problems at public chargers. I charge once or twice a week at my home PodPoint charger with no problems. I've now been on the road since 05:00 and it's 11:33 and I've tried two different public chargers ( BP Pulse and Genie Point). I'm having the same problem at both chargers. When I try using CCS I pass all the connection tests but they fail to give me any charge. I've contacted both tech admins and they've rebooted the chargers several times to no avail. I've then tried the Type 2 connections and they have both connected and charged. Has anyone else had this problem? I have a MG ZS EV Exclusive and it's red if it helps.
I use Podpoint and have used both CCS and type 2. Seem to be reliable and reasonably priced.I'm on my first long run in over a year (Doncaster to Tenby) and am having problems at public chargers. I charge once or twice a week at my home PodPoint charger with no problems. I've now been on the road since 05:00 and it's 11:33 and I've tried two different public chargers ( BP Pulse and Genie Point). I'm having the same problem at both chargers. When I try using CCS I pass all the connection tests but they fail to give me any charge. I've contacted both tech admins and they've rebooted the chargers several times to no avail. I've then tried the Type 2 connections and they have both connected and charged. Has anyone else had this problem? I have a MG ZS EV Exclusive and it's red if it helps.
Or a tin of quality street & some smooth talking?Seems to be the only way to deal with MG dealers. Swift, direct, action.
So do you take the chicken bones with you or can you only charge at KFC after eating a bargain bucket ?I'm just about ready to set off home to Doncaster from Tenby and I've charged using CCS several times and I think I've cracked my charging problems. It doesn't matter if the car is on or off, locked or unlocked, Red or blue. What you need is a handful of chicken bones. Whichever charger you use either plug in first or get the app working before plugging in then throw the chicken bones onto the floor. Then the charging will start or it won't. Simples.
Of course you can only use one of the 15 “Non” Tesla super chargers on trail in the U.K.I think might be worth a try to Ionity or Tesla.
Yes i am in the same boat> I had my car for almost two years and it only works from the home charger.Tried in Calais yesterday and at the hotel with no joy.Soooooo frustrating.I'm on my first long run in over a year (Doncaster to Tenby) and am having problems at public chargers. I charge once or twice a week at my home PodPoint charger with no problems. I've now been on the road since 05:00 and it's 11:33 and I've tried two different public chargers ( BP Pulse and Genie Point). I'm having the same problem at both chargers. When I try using CCS I pass all the connection tests but they fail to give me any charge. I've contacted both tech admins and they've rebooted the chargers several times to no avail. I've then tried the Type 2 connections and they have both connected and charged. Has anyone else had this problem? I have a MG ZS EV Exclusive and it's red if it helps.
We had a problem in Tasmania with fast charging, only once though. Most times it has worked when we needed them. The one time the fast charger would not work, I tried holding the plug up to make sure the communication pins were connecting. No go, I gave up after about 5 tries.
When we got home I disconnected the 12 volt battery for 10 or more minutes. The next time I tried the fast charger it worked fine. I rarely use fast chargers and never have problems charging at home using our Zappi or any other home chargers
Ours is a Gen 1 ZS EV
Pete
