redwood98
Age
23
Bedfordshire
I have seen a few posts about this upgrade but most just link the ones they are planning on getting and no one seems the link the one they got or that link doesnt work anymore. Can anyone link the ones they bought as there are too many choices, preferably I'd like it to light up the back too although I know it's not going to be able to light up the back footwell.
@Kenp1, with the change to LED's do the interior lights still fade out when the doors are shut, or do they tend to stay the same brightness and then just go off?
The light switch each side just turns them on and off but the door close produces a theatre dimming effect.
from reviews I've seen they don't dim, I think that's because the original aren't led. I think I'm going to get this one as its apparently the upgraded newer version of the other KATUR one, 150 lumen more too.
That's a pity, I suppose it's in the fuction of the buck regulator used within the LED assembly to keep the brightness constant over a range of input voltages
Yes I think it has some circuit or resistor built in for the canbus but no pwm to control the brightness.
I have installed my lights now, very straight forward you just pry the plastic cover off and pull them out (you can find videos on it) and the brightness is definitely a massive improvement, especially as I haven't added a light in the back yet.
These are reduced at amazon at the moment.
Can I ask what the advantage is?
Is it just that they provide extra light? Or do they provide extra light while also using less energy?
Or is it nicer light?
Extra light, daylight 6000 kelvin (daylight) colour temperature instead of the bulb which is more like 2700 kelvin. (yellowish colour) Since it’s a led it should be more efficient too yes.
