At least you don’t have to worry about exhaust extraction.
The issue is NOT caused by excessive heating but by the positioning of the breather fitting directly in line of the crown wheel oil fling. As things heat up the expansion of air/oil in the 'box seems to push tiny blobs of oil out of the breather after they are thrown into the channel.
That's a much better cause then overheating but still hard to solve?
Internal baffle would help - but I guess a bit late for that and too expensive as a retro-fit. MG want a fix that will get them out of trouble with the least cost.
I've sent my design with detailed drawings to MG, royalty free.
Not at all hard, many gearbox units suffer in the same way, hence the widespread use of expansion vessels to catch the oil and allow it to drain back as necessary.
It might well be the case that the internal end of the breather could have a deflector attached to it although I'm not clear if there is sufficient space.
MG really are missing a trick here. They could modify the bulging under tray so that it catches any displaced oil - job done! Both issues resolved!
How far up the pipe has the oil gone?
Not sure as yet, will give it a peek tomorrow if I have time. Hopefully the oil will leave a trace and I can possibly reduce the 12 inch length (ahem)
There's only around 5 inches free space above the breather outlet before you hit the boot floor so I've had to coil it a bit, cable tied the end with the original breather to a bracket.
Tons of empty space below the rear seat however, so you could terminate it there high above the gearbox if necessary.
Ended up using a hose, clips, and a bit of m10 hollow threaded tube I had lying around the garage so have spent nothing in reality.
The 4 'box ejected about 1.5 ml of oil over the test whereas the 5 ejected none (not a surprise) but there was a tiny touch of noticeable oil mist when fully heated.
Interesting stuff. I presume the 5 had a length of tubing 'tween 'box and breather as is more normal ?
No, the 5 has a very similar breather to the 4 (but plastic) directly on the casing, albeit not in line with the ring gear!
Ah ok, they must have thought, well it worked this time, so why not. The motor output shaft on the 4 is below the breather and I think it's gear is low enough to be in the oil bath looking at the bearing end cap position but I might be wrong.
The intermediate gears are higher up, the ring gear is deeply submerged of course, can see the bottom of it through the drain plug.
Oil could be firing from all directions I guess.
Just surprised talented designers could have thought that the 4's set up wouldn't leak. Tiny breather with a 4mm gravity ball valve you can easily push by just blowing, how was that ever going to work.
    Votes: 1,089 77.8%
    Votes: 209 14.9%
    Votes: 103 7.4%
