MG4 Secret Menu Mode...
Or if the screen is flicking annoyingly into dark mode when the lights come on in daylight (see elsewhere for how to fix that), simply switch manually to dark mode when it gets dark. Some people like to run in dark mode all the time.
Dark mode all the time makes the two screens match much better and it is still easily visible in the day. The lack of auto brightness adjustment is a shame as is the driver's screen not going dim enough for night work.
How do you turn down the brightness on the white screen at night?
If you mean the centre screen, then swipe down from the top of the screen on the right hand side (and left, I think, but not near the centre as that brings up the HVAC controls) and you will get a selection of controls. There is one for the brightness of the screen.
Also, as others have said, there is also a dark mode, which is what I use all the time.
Voice commands? You don't need to use the screen for most things.... allegedly. Have fun trying them. Still trying different ways to say Turn ***** LKA off, but doesnt seem to work... ye :cautious: t
Radio
Play Radio / Play FM Radio
Play 106.5 FM (Station Frequency)
Play favourite radio station
Save this station as favourite
Remove this station from favourite
Pause radio
Next station
Previous station
System
Make screen the maximum level of brightness
Make screen brighter
Lower brightness
Make screen the darkest
Increase the volume
Volume Down
Volume maximum
Volume minimum
Mute
Unmute
First page
Last page
Previous page
Next page
Go to page 2
Pause radio
Resume
AC on
AC off
Temperature up
Temperature down
Maximum temperature
Minimum temperature
Raise temperature by 2 degrees
Lower temperature by 2 degrees
Set temperature to 22 degrees
Increase fan speed
Decrease fan speed
Highest fan speed
Lowest fan speed
Find charging station
Check remaining range
what is the remaining charge
Open settings
Help
Media
Pause music
Resume music
Next song
Previous song
Loop all
Repeat all
Single loop
Repeat song
Shuffle
Navigation
Open map
Zoom in the map
Zoom out the map
Switch to navigation
Find (hospital, restaurant, petrol station)
Set home address
Set office address
Go home
Go to office
Zoom in the map to maximum
Reset map zoom level
Where am I
Cancel route
Switch to fastest route
Switch to avoiding tollway route
Phone
Call 04XX XXX XXX
Call Dad (contact)
Call back
Redial
Radio
Pause radio
Next station
Previous station
System
Lower brightness
Increase the volume
Volume Down
Volume maximum
Volume minimum
Mute
Unmute
First page
Last page
Previous page
Next page
Go to page 2
Pause radio
Resume
AC on
AC off
Temperature up
Temperature down
Maximum temperature
Minimum temperature
Increase fan speed
Decrease fan speed
Highest fan speed
Lowest fan speed
Open settings
Help
Media
Pause music
Resume music
Next song
Previous song
Loop all
Repeat all
Single loop
Repeat song
Shuffle
Navigation
Open map
Zoom in the map
Zoom out the map
Set home address
Set office address
Go home
Go to office
Where am I
Cancel route
Phone
Call 04XX XXX XXX
Call Dad (contact)
Call back
Redial
How many have you tried?
I’d like something useful like heated steering wheel/seats or drive mode. Both of which are a bit buried in menus when using AA/carplay.
But if wishes were fishes…
If you're interested to accessing secret menu in the SE version, go to the phone keyboard and input the code ##4479#*
OK, somebody has to do this now. It will not be me. Have at it.
Don't stress, you can't break anything in that menu. It's the same one the dealers get to do updates and see version numbers.
You can't actually do any harm in there.
There is an extra level of engineering menu in there that we don't have access to yet.
If you tap the bottom right corner of the engineering screen 5 times, a password box pops up. We haven't cracked that one yet.
    Votes: 1,031 77.6%
    Votes: 201 15.1%
    Votes: 96 7.2%
