MG4 Software Update Thread
Hi Rossco and welcome to the group.
I have found that the A/C temp on mine is not the same as any other car I have driven. I usually set mine to 24 degrees C on other cars, the MG4 I have it on 26 degrees C instead.
Have not actually used the Sat Nav at all, well not the OEM one. Most use other navigation apps. In mine I have Waze, Apple, Google and Plugshare. All have pro's and cons. If I were doing more long trips I would subscribe to ABRP and use it.
At the moment I am trying to get my software updated. Seems there are differences in various markets. I am dealing with MG Australia.
Ive just Purchased a Sep 2025 pre Reg Xpower. What software version should this be on. Seems to be blowing out cold air at 22deg C. Also Sat Nav seems to be way out of date
Initial 4s you had to set the heating about 4/5° higher than you wanted to get that heat, so for 22 set 26/27.
That has been fixed with an update,
I hope to God the Bluetooth issue is fixed, it' worse than Clippy from the 90's
I see that the Bluetooth issue has been fixed but, now we've got that stupid brightness problem back again:
Do you reckon the MG coders all have the same mouse mat as me?
Honestly, I don't think the car's gone for a single day in the last 3 years without something not working properly. It pains me every time I get in it. And on the hottest and coldest day's, when you actually need remote climate control, the pissing thing doesn't work.
Just back from the MG Service Centre.
Apparently there were two modules which should have been updated before the car was sold back in Nov '23. The AEB module was also meant to be updated. Apparently it causes the sudden deceleration when it detects oncoming traffic. The Tyre Pressure Monitor also had a known fault.
All modules are now the latest versions. Tried the ACC on the 10km drive home. It now changes in 1kph increments and does not slow down in the middle of corners. So far it seems a lot better behaved.
A slightly longer drive today. The software updates do make it much better to operate. A lot less lane alarms and no taking control of the wheel.
Takes a bit of getting used to the 1kph increment but I will and like it. Hoping the High Beam control will also be improved, but that may be too much.
My car was in for all software updates on Wednesday. The ELK button was not created in the quick drop down menu even though I requested it. This was an early AEB update which may have been superseded with the full LKA etc update. I haven't checked if the route planner was updated in the Infotainment system yet but there is a change to LKA. I deliberately ran off the lane & there were plently of beeps and a less intrusive steering tug than before. haven't checked whether it doesn't slow for corners. I never really noticed this on the motorway anyway. It was sort of useful on B roads but was not consistent so could not be relied upon.
The ACC increments in 1km steps. To be honest I'd got used to the original 5km steps so this is less convenient now. If I now set the ACC 3km too high or low for the actual speed limit I need 3 presses to get to the limit. Before it was 1.
The car now gives me the welcome call when I open the boot or any door & also when it is in ready state. Before it was only in ready state.
The headlights full beam was adjusted but I haven't driven at night yet to test it. I don't find the screen brightness a problem at night. It is set to auto.
The temperature setting is now better. 25 deg was the minimum for comfortable driving & any cooler I froze.. Now on 21 or 22 & it is about right.
Another odd thing is speed sign recognition. It still reads them all including off ramp signs but that is common to most cars but now it forgets the speed after a few minutes from the last sign & it changes to all dashes (no speed) till another one is seen.
There will probably be other things so I will report them as they occur
If you hold the button a bit longer it will change in 5kph steps, like it did before.
Just takes a bit of getting used to the change.
And the 1/5 change is actually easier ... previously if I wanted, say, 53 mph as the target it was hellish hard to reach it as the long hold and 1 mph changes was difficult to control; long hold and 5 mph changes is easy to control. :)
I prefer the hold for 5 and push for 1. I'd prefer it even more if it was hold for 10 and push for 1
I'm not a fan either, I've turned off all the voice queues. I'd turn off all the dings and bings too given half the chance. I've set the alert volume as low as it will go but it still annoys the hell out of me. During a single short journey I'll get about 10-20 or so warnings for various things. I know it might be icy, stop reminding me, I'm not going to forget, I'm freezing my nuts off :ROFLMAO:
I've just stuck a black round sticker over the part of the instrument cluster where the speed flashes away. I gave up on disabling it every time I got in the car.
Same here.
The lack of option to quickly dismiss ELK is mildly annoying. It sounds to me like you got the same updates I did , i.e. not whatever the full update suite is but all the required safety system updates. Fortunately the ELK is much better behaved and so I just leave it now. It's chalk and cheese compared with how mine behaved before (which ranged between awful to dangerous).
The ACC speed change control is much better IMO, the long press for 5km/h adjustments actually works pretty well, unlike the 1 km/h increment change before which was impossible to use.
If you over/undershoot your set speed target the long press (and it's not all that long) will still get you there in one go. Way I think of it: Quick nudge = 1 km/h, slow nudge = 5 km/h, latter I'm mostly using when entering/existing the freeway 110 km/h zones.
I recently upgraded my Lux from R63 to R67 via USB. The BT issue got fixed but I have a new issue now.
While I still can charge to 80 or 90% voa dropdown or smartphone settings it doesn't seem to "stick".
The car shows 80% after charging - so far so good. When driving the batterylevel does not go down as fast as it should for at least 100km but pretty much half of the actually usage. I know thisbl because I drive the same route everyday. ;)
Is there any additional update I'd need to do?
Another couple of observations since the software update.
Screens are a bit faster than before. I notice this when shutting down when I press Car-Safety-Shutdown & confirm.
Bluetooth has not disconnected since the upgrade.
Yes the ACC speed change is definitely much better now after the explanation WM.
Had my Xpower software updated today, IT to R67 plus a bunch of sub modules. Great service, called me up last week to say they could do it today, took about 2 hours.
Should be a good service when you get it done at your own work😁
I guess that the underestimated energy consumption comes from a reset. About the charge levels: no clue.
Has someone here updated the MG4 + versión by manually using a USB? My dealer in Colombia said there are no updateas but my car is running R32. I am really outdated.
Any help much be appreciated
You need to read a little more this thread : RXX isn't enought to say i'm up to date or not.
You need the all build number like SWI68-29958-1300RXX
R32 usually refer to SWI133-29176-1300R32 which is Luxury (Trophy) version for 2024 MG4 (V3 version). So R32 is pretty much one of the latest for MG4 Luxury/Trophy 2024 (V3) model.
For V1 and V2 (2022 and 2023), it's SWI68-29958-1300R67 and R67 is the latest known version forLuxury Trophy.
And if you have a Standard/SE or Standard ER, it's another build (SWI69 for V1 or V2 model (2022 and 2023) or SWI132 for V3/2024 model)
To be correct, you got a 2025 (registred in 2025) XPOWER based on a 2024 model with SWI133 build, R32 infotainment version.
Model Year and registred year are not always the same : I got a 2022 model manufactured in 2023, resgitred in 2023. But it's still a 2022 model
    Votes: 1,094 77.8%
    Votes: 211 15.0%
    Votes: 103 7.3%
