MG4 Software Update Thread
Awesome resources, thanks!
Should I start with the TBOX update first to proceed with the FICM update, or is the order unimportant?
I think its not important.
I updated TBOX at the end.
In the meantime, I tried to obtain the VR files from MG to get the voice assistant running.
Response from MG support:
„We refer to your email and the issue described therein and inform you that image files for the voice control cannot be downloaded.“
I don’t know if this helps, but in an MG4 Facebook group, someone commented that the control unit for the internet had to be replaced for the weather and other functions to work again.
I did not understand the part about "it's important to update the software via SIPS."
Me neither. I assume we shouldn't update the software via USB if we don't have the SIPS module to reprogram once the update is completed, right?
The instructions say:
1. "After the TBOX MPU (SOC) update has completed use SIPS to reprogramme and configure the TBOX ECU".
2. "Once the USB software has been applied and the Factory reset carried out, it is important to update the software Via SIPS. For the R63 update, the software for the FICM (config and Calibration) and the HVAC (config and calibration) software must show ticks in SIPS."
Weather and user interactions are back this morning, so hopefully people will be able to
Activate and also pair with iSmart
I contacted austrian support/service yesterday, and even told them the server thats not working. They (someone with title 'technical lead') replied that everything was fine.
I then contacted the email that is given in the ismart smartphone app, but didn't get any response yet.
Got the up notification from my status website at 5:13 CET, so clearly someone repaired the thing...
Go into engineering menu activate and click activate avn.
I contacted MG today who confirmed there was an AWS issue.
Updated via SIPS the FICM and also Tbox using the usb and reprogramming on SIPS.
Battery slider is back on r63. Have another number of updates but currently doing them one by one incase of any issues.
Glad this forum exists as dealers are basically trying to charge you £250 just to update it
How did you Update with sips? Do you Need a Special Software of do i Need to Buy a Account to do the Update myself?
Both and also a VDI dongle. Check this thread out…
    Votes: 1,031 77.6%
    Votes: 201 15.1%
    Votes: 96 7.2%
