MG4 Software Update Thread
I have MG 4 Standard 51 kWh, 2024 model.
My dealer updated the MPU from R33 to R40, but my MCU is still version 69.3.8.0
Do you know what changes are included in the newer MCU versions?
Also, how can I convince them to update the MCU as well?
There are two equally valid approaches.
The first is: “If something isn’t broken, don’t fix it!” This helps avoid unwanted bugs, but at the same time, you miss out on the latest upgrades.
The second is: “If there’s a new version, there’s a reason for it.”
When the MG4 was launched, over-the-air updates were promised, but they never actually materialised. I feel that we are entitled to have an up-to-date car.
Keyboard for Sat Nav is much better. The R40 size was a joke.
As far as Bluetooth pairing is going, it's paired but now I'm not seeing it playing on the screen (however the buttons to move backwards forward, volume etc are working).
Cannot see anything obvious what has changed. At least now 21oC is c.21oC and not needing 25oC
When I was referring to R40, I actually meant the 1100R40 (designed for the SE), which was released last month at the same time as R67.
The previous versions were 1100R38 for the SE and 1300R63 for the Trophy, respectively.
FTFY ;)
Probably.
I can confirm it is available on
Hello,
Is Turkish available as a language option in the settings in the R67 version? Could you please check it?
Thank you.
i can’t tell for sure…
But it’s included in R40 (for the SE)
    Votes: 1,082 77.7%
    Votes: 208 14.9%
    Votes: 103 7.4%
