Thanks - just updated my Trophy (also R33) and probably would have given up if you hadn't mentioned the greyed out button. It took 2 or 3 minutes for that button to become active so that I could start the update. The update then took a further 35 minutes or so. Downloading and extracting the data took ages!I updated the maps in my Trophy (R33) today. After hours downloading and extracting, the data needed about 40 minutes to update the maps. I was concerned after I plugged in the USB drive to view greyed-out text asking me to select a resource in a window with a lit Cancel button but it came good in the end without intervention. I attach a series of images from the sequence
You can only update navigation if infotainment software lower than R40. If you have R40 R46 or R59 then it fails with the no VN file message. Seem you have R46Same for me with Trophy extended
Infotainment version = 1300R46
Nav = 6.2.60.1.45160
This is still the same old map-update without VN-file.@MrPeaski, I have tried this morning
Downloading https://cdn.mgmotor.eu:443/map-data/map-update.zip
NONE/JV/HERE/EU/23Q3/20230804103215/
try with direct url " https://cdn.mgmotor.eu:443/map-data/map-update.zip"
For your information, this nodejs script allows to check version of map file without download 17 Go
direct link:
source : MG4 France
In fact, the map seems to be a q1 2023 version..This is still the same old map-update without VN-file.
version.txt shows:
23Q3 202302280415_t
1165894901
Maybe you have a Chinese cloned vehicle?MG UK have provided me with this link for Map updates.
https://tiov-mapmg.soimt.com/#/downloadMap
The problem is - this site does not recognise my VIN!!!
No I couldn’t do that either!The website seems better, did you generate the signature file?
That looks like the process for the 2020 ZS, where you have to take a fingerprint file from the car.MG UK have provided me with this link for Map updates.
Hey Frans. Is your dealer in Rotterdam?I tried to enter the VIN number, it was invalid VIN.
The the website shows: "1.Export the fingerprint file from your vehicle by using U-disk.(You can export it from the resource upgrade in setting on vehicle)"
There is no way to export the fingerprint file and there is no U-disk and no resource upgrade under settings.
This all is so bad, I regret very much I bought a Chinese car, first time and last time.
Nijmegen .... Maybe I go there, cost me some time but will save from finding updates from here.Hey Frans. Is your dealer in Rotterdam?
@Rockstar@MrPeaski, I have tried this morning
