Lillemy
Is there only one USB port that is connected to the infotainment system? I usually have an USB stick with music on in my car, and would be nice if I could use both the stick and phone with android auto at the same time.
So does that mean you can plug a USB key with your music on into the back socket and your phone to provide Android/Apple auto/carplay into the front?From Manual
The front power socket is located in the front of the centre console. When the vehicle is powered on, it can be used as a power supply.
There are 2 USB ports (1 & 2) equipped both sides of the 12V front console power socket. The USB ports can provide a 5V voltage when serving as a power outlet, or realize data transmission. USB port 1 can also provide‘Vehicle-Mobile Phone Interconnection’ function.
Would be nice to be in simple English, not tech speak
Could you put the music on the phone and have it run as files from there or over the bluetooth?Is there only one USB port that is connected to the infotainment system? I usually have an USB stick with music on in my car, and would be nice if I could use both the stick and phone with android auto at the same time.
Tried that yesterday, I don't think the pad does lift off(magsafe), only had a quick go, couldn't get them through. I'll try again later.This is likely a daft question - how do you feed USB cables through to the phone tray?
Feels like the cut-outs might snap if I prise too far. I assume you push cable up from beneath?
It’s not mag safeTried that yesterday, I don't think the pad does lift off(magsafe), only had a quick go, couldn't get them through. I'll try again later.
BTW, found the magsafe pretty crap and intermittent on my iPhone 13 pro max
That would explain that thenIt’s not mag safe
Yes mate, no magsafe involved here just wireless charging. The type of case you have on can affect the performance. I have the Apple silicone case which is also mag safe compatible if you need it (ridiculous price I know) and it works perfectly with the MG wireless charging on my car. Also I don’t get any movement or slippage round corners that I have seen others mention.That would explain that then
