Miles/kWh
You reposted this mate curious as to the reason
Just that when doing the occasional long trip and trying to plan how to only charge once, I try to plan as long into the trip as I can for the stop. I assume the range of 160ml needed from a full charge depends on getting at least 3 mls/kWh for the whole trip. So when halfway there and I see 2.0mls/kWh displayed, I wonder/panic about getting there.
Just that when doing the occasional long trip and trying to plan how to only charge once, I try to plan as long into the trip as I can for the stop. I assume the range of 160ml needed from a full charge depends on getting at least 3 MLS/KW for the whole trip. So when halfway there and I see 2.0mls/ KW displayed, I wonder/panic about getting there.
I think you are paying too much attention to the GOM, the mg4 rough figures for summer and winter are well talked about on here.
Below is from EV database and it's pretty accurate, 180-195 is what most see in winter for combined range
Think I may have a battery problem then as the most I've ever got is 170 miles in a single trip. 260/330 ???
278 miles, I believe.
It dropped to 428 when I put the A/C on, then back to 408 in NORMAL mode, which is how Iusually run it.
In winter, it was down around 360-370km, and that felt fairly accurate. Lop another 10% off for highway driving (steady 110kph).
Yeah I’ve see a consistent 350km range over winter doing a fair bit of highway driving. Now with the weather heating up and doing some more city driving I’ve crept back up to 400km range.
I'm surprised Reintje, our 51 can get as low as 13 in the burbs. On our drive to Bridgetown, going up the scarp, it was about 17.
But we haven't seen the predicted range the wizard gets. I think the best I've seen is 410.
Very much doubt we ever got that.
Edit, I was driving fairly slow though, as Dot wanted to detour, and I wasn't sure of our range.
At the moment it's showing 266km @ 76%. about 14kWh/100km.
But we haven't seen the predicted range the wizard gets. I think the best I've see is 410.
Very much doubt we every got that.
At the moment it's showing 266km @ 76%. about 14kW/100km
Yes that’s pretty good, I do drive shall we say “spirited”. I don’t really mind the figures, I have the range I need and can charge pretty much whenever I need, so it all works out.
I have my moments and enjoy them but rarely keep it up for long.
Being first at the lights, is often a temptation I can't resist.
Especially where there's a merging lane just after the lights.
There's a good excuse for rapid acceleration then, to get out of the way.
👍 not sure I've ever had 4 in the 18 months I've had the car. Remember seeing 3.8 .
That's spooky! This is from the end of September. I've just been and checked, at 54% the estimate is 125 miles - I think that your estimate of 160 miles on a full charge is low, or there is a problem somewhere. Have you checked under the car to see if you've got an electricity leak? 🤔
Wow that’s real good range then, what’s your consumption like? Mines always about 19 or 20 kWh / 100km. A short drive might show 15/16 but long term tracking is definitely 19+
The most I've consumed was driving to Northam during the middle of winter, used about 36% over 100km, but that's uphill as you know*. Generally, I'm around 14-15, but over the last month I've been 12.5 to 13.5, depending on whether I'm using AC or not.
* Used 30% on the return journey.
    Votes: 1,052 77.9%
    Votes: 204 15.1%
