Service book and charging port cover
teejayuu
Solutions
Age
64
Leeds
MG4 (2022-2025)
Hello all,
Bought my Trophy a couple of months ago. Have a few issues that have been covered in other threads so will not list them here and go over old ground, but I have a couple of questions:
  1. I don't seem to have a service book. Is this normal?
  2. Should there be a cover for the main charging port? There is one attached for the bottom (2 pin) socket. Just a bit worried about getting water in it.
Hello all,
  2. Should there be a cover for the main charging port? There is one attached for the bottom (2 pin) socket. Just a bit worried about getting water in it.View attachment 18872
But nothing stops you placing a cover , so whats the problem ?
I have charged in the rain and worried about water ingress but not when the port door was shut. Although there is a drain socket I covered the gap between the open door and the car with cling film to keep out the raindrops. You could use similar inside if you are worried. Also, avoid pressure-washing in that area.
The charge port is well protected when the cover is closed, as per the message on the cover arm, don't wash with it open.
When it's charging with the socket plugged into it, it forms a seal around the connections and pins are set down within the body of the socket. A manufacturer will have to meet a safety standard with the car so exposure to electrocution is negligible I would expect, so all should be good. That said it would not harm to place a cover over the port and lid when charging outside.
    Votes: 1,096 77.7%
    Votes: 212 15.0%
    Votes: 103 7.3%
