maskull
- Mar 17, 2023
- Location
- Rhondda Cynon Taff
- ZS EV
250 miles .
The Home Assistant integration I have doesn't report SOH. I don't know if that's a limitation of the integration or of the information available via the SAIC API.Dealer only with the MG4 (unless you can find it via the Home Automation route? See posts by @wattmatters). Other models might be able to get the info via OBD2/11.
Why the 2 (differing) SoC values? (SoC and SOC)The Home Assistant integration I have doesn't report SOH. I don't know if that's a limitation of the integration or of the information available via the SAIC API.
But my OBD reader does show a SOH value:
Since it is reporting a 100% SOH value, I guess I'll have to wait to see if/when it drops below that to see what it says and what precision level it reports.
I think one is the "reported" SoC (what you see in the car) and the other is the actual SoC taking the reserved headroom/basement into account.Why the 2 (differing) SoC values? (SoC and SOC)
Given MG state an accuracy to within 3% for their SOH algorithm an answer with a lower value in year two is possible if there is only modest decline.Lol...
first service SOH =95%
Second service SOH = 100%
new advertising from MG "Self healing technology"
You’d be surprised how may people can’t tell the difference between SoC/SoH, dealers included..Given MG state an accuracy to within 3% for their SOH algorithm an answer with a lawyer value in year two is possible if there is only modest decline
Yeah ours was listed as 95% at first year MG service. Not sure if they checked or assumed. Also hoping that was the initial drop which will tail off.my mg 4 se sr is 6 months old now. almost 5k miles and OBD reader claims 95% SOH. I'm hoping it will plateau out shortly from what i read. but maybe it just follows some MG algorithm. interesting thread to me, to se others LFP SOH
Spot on, you can make a 65kWh NMC battery and label it 61kWh (as an example) but the lower energy density of LFP won’t allow to go much beyond what’s written on the label, therefore initial, rapid degradation is more pronounced but doesn’t really matter at the end of the day..I think these initial drops are hidden for the other chemistries because they have a much bigger buffer.
