My MK1 went back in today after the column was changed less than 500 miles in. I was worried that the dealer wouldn't experience the rattle. They felt it too and found that some of the bolts had worked there way loose so they have tightened them up.
Feels much better now just like after the column was replaced. I'm not holding my breath as I think it's going to keep happening and I suspect I'll be back at the dealership in another few hundred miles. I can't fault the dealership they always seem to do the best they can I think they are just let down by MG and the build quality.
If I remember correctly, there are three bolts that attach the steering column to the body shell / structure of the car.
Two pass through brackets welded to either side of the outer steering column and a third bolt that is accessed from under the wiper scuttle panel on the outside, this secures the outer column to the bulkhead of the car.
These bolts are very likely to have a flat washer and a spring type washer to prevent them working loose.
They may even have some type of hi-lock solution applied on the threads as a safety feature.
With these precautions, it is extremely unlikely that these fasteners will just work loose in this short time frame, if they where torque to the correct factory spec's ?.
Of course the steering column is adjustable in a "up / down" fashion by the driver(s).
To achieve this they need to have a clamping mechanism that can be released by the driver when the clamp is opened, this is achieved via the handle placed to the left side of the steering wheel.
When the handle is dropped, it allows the column to raise and fall.
Lifting up on the handle traps the holding clamp to the outside of the steering column upper top bracket.
It has been noted, that sometimes when the handle is lifted, it does not apply enough clamping force and a rattle can be evident.
I know that
@Kithmo had discovered this to be the problem on his ZS EV Gen 1 a long time ago.
Can you verify and expand on how this fix has worked ( or not ) on your car please ?.
I may suggest that the rework on your car
@Uevinysses was cured in a similar fashion maybe.
After 500 miles of settling down, the upper clamp may have required an extra retighten.
This maybe what the dealer is alluding too ?.
