Trophy still supports 3 phase AC charging ?
Hi, I have plugged my Trophy into a 22kW 3 Phase supply and can confirm that it charges at 11kW (9.5kW to the batteries).
Here is what my connection looks like and my charging screen:
I just got a 2022 MG4 Trophy Long Range as a long term rental car atm, it has the extra pins for rapid charging but I keep reading conflicting reports on how fast this car will charge. Has a standard type 2 cable with it. Can anyone confirm?
If by "standard" you mean "single-phase" then it'll charge the car at up to 6.6kW (which is the rating of the onboard charger). Use a 3-phase cable (rated to 32A per phase) then he'll get up to 11kW (more like 9.8kW) from a 3-phase charge point (typically 22kW), or up to 6.6kW from a single-phase wall box.
Hi, the extra pins on the type2 socket are not for rapid charging.
The two separate pins below the type2 are for the CCS rapid connector.
    Votes: 1,086 77.7%
    Votes: 209 15.0%
    Votes: 103 7.4%
