Vehicle Clock / Time Wrong
enisdem
london
Anyone has a same problem or a possible solution to time of the vehicle is wrong for GPS GMT+00 ? Its an hour ahead.
I tried manually changing it but everytime its off it decides to reset it to the wrong setting
I ll try but dont you think its weird you have to do something to get it right ?
I guess MG needs to consider having a software update asap as i see there is so many issues going on.
Its exactly same as on the Kia and Hyundais we had before in Winter you have to untick DST to get it to drop back to normal time.. When DST starts in Spring you will need to turn it back on again
Thanks very mich for this,
I believe this is going to sort it out
Starting handle?
And an electric starter, which worked by pulling on cable/knob on the 'dashboard'. This was attached to an arm on the starter motor. No solenoids as I remember!
This isn’t an “issue” though.
By design choice, you don’t need change the clock manually, twice a year use the slider to set +1 hour for summer or Daylight Saving Time. The feature is named that for a reason.
I have the same problem, except that we are in "summer time" So I will have to put the slider in the ON position. If I do, the time displayed is one hour too long.
I seem to remember that switching to taking time from DAB/RDS rather than GPS avoids this issue.
    Votes: 1,096 77.7%
    Votes: 212 15.0%
    Votes: 103 7.3%
