Rolfe
Moderator
- Apr 10, 2023
- West Linton, Scotland
- MG4 (2022-2025)
Now at Cherwell Valley having coffee.
Are you heading home?Now at Cherwell Valley having coffee.
The poll is now Weetabix or Porridge.The poll is still open for 21 minutes. Wonder how people will vote now?![]()
Probably gave him a thrill, a bonny young lass following close behind him ..... driving through the night in such bad weather, glad you made it home safely .... now I guess you will be sleeping all day, you people certainly have strange sleeping hrs over thereHome now. Had a small hiccup when I left him on a charger at Tebay without realising the charge hadn't properly initiated, and didn't realise until I was sitting down to a plate of lasanga. So I had to go back out into the rain and wind and get it started again. Probably lost about 20 minutes. Then the weather was atrocious most of the way home so I probably lost another ten minutes just going slowly. I identified another car going about the speed I wanted to go and latched on to him with the ACC. This continued for close on 75 miles. He probably thought I was stalking him, until I turned off at Abington and he went on. But it meant that all I had to do was steer to follow him. No hassle keeping to a speed and no need to put lights on full beam at all.
We made it over the Shap and Beattock Summit. That was enough for one evening in this weather.
Without giving away your home location, are you N, S E or W?
While we still don't know the percentage HV SOC at which the car still charges the 12V battery, my guess is that it is quite small, probably 5%.
The 50% might possibly have been true in very early software releases, but I cannot believe it is true for the vast majority of people or we'd have dozens or hundreds of reports of 12V battery draining.
So, my guess - and it is just a guess so could be wrong - is that this was sorted out early on.
Yes, this is a crucial point. EVs have a far gentler load than ICE engines on the 12V battery, and they are topped-up in a different way.The big difference though is that for an ICE vehicle the 12V battery is needed to crank the engine, which will draw a huge current, especially with in a diesel engine, as well as run the vehicle's electronics. With an EV, the 12V battery only needs to power the electronics enough to put the car into 'ready' mode. Hence - in theory - should be good to be left a bit longer.
Which is I think why MG recommend disconnecting the 12V battery if you are leaving the vehicle for a month or longer.Having said that any LA battery will have a degree of self-discharge and unlike LFP or NMC batteries, a lead-acid battery should not be discharge to more than 50% of its capacity. Hence, I'd say you're looking at max of 3 months for it to be in a state to crank a petrol or diesel engine.
